On 14 April, British Airways flight #BA2698 (Airbus A320 reg. G-MIDS) to Faro declared an emergency and returned to London Heathrow at low altitude. Depressurisation?
Diversions from around the globe (medical, technical, ...) 2022
Re: Diversions from around the globe (medical, technical, ...) 2022
On 10 April, easyJet flight #U22213 (A320neo reg. G-UZHA with "neo" livery) from London Luton to Agadir was forced to make an emergency in Faro landing after the captain dislocated his shoulder in the cockpit (how did he manage to do that?)
Someone knows why SN3139 to Florence was diverted to Pisa this Easter morning ?
Not only SN. Several other aircraft were diverted either to Pisa or to Bologna, while others landed normally. I have no answer to your question, except that it is probably airport-related.
Florence Airport is close to a mountain. The wind or other weather related aspects play an important role at the airport. But I can’t say why certain flights land or divert.
Ok, I sée. I suppose it had to do with the windgusts that were/are present.
USAF flight #RCH470 (Boeing C-17A Globemaster III reg. 04-4130) is declaring an emergency and diverting to the UK (Glasgow Prestwick)
Delta Air Lines flight DAL4 from London Heathrow to New York JFK (Boeing 767-400ER reg. N-833MH) diverted to Dublin. Reason unknown.
Air France flight #AF792 from Paris Orly to Pointe-à-Pitre (Boeing 777-300ER reg. F-GZNO) is squawking 7700 and returning to Paris.
Diversion from Amsterdam after some holding.
Reason unknown.
No fog in AMS.
Reason unknown.
No fog in AMS.
Not only airBaltic from Vilnius, but also Finnair from Helsinki, SunExpress from Antalya and Atlas Air from Almaty diverted to BRU, while a KLM flight from Hamburg diverted to Groningen, and KLM flights from Lisbon, Rome, Bremen and Zagreb to Rotterdam. Swiss from Zurich diverted to Dusseldorf. Furthermore, many flights were cancelled.
Amsterdam looks like a mess today!
The reason is a lack of capacity at Schiphol.
Runway 09-27 is closed for urgent maintenance till 26th April.
Runway 18L-36R is closed for heavy maintenance till Mid July.
https://www.aviation24.be/airports/amst ... cancelled/
Luckily, luchtvaartnieuws.nl clearly says "omdat er op Schiphol te weinig capaciteit is vanwege baanonderhoud en drukte", and further "KLM heeft vanwege die beperkte capaciteit ook al preventief vluchten moeten annuleren". But I accept your statement that it means nothing, except for the affected passengers!
Sorry to say but the article is poorly written.sn26567 wrote: ↑25 Apr 2022, 17:06Luckily, luchtvaartnieuws.nl clearly says "omdat er op Schiphol te weinig capaciteit is vanwege baanonderhoud en drukte", and further "KLM heeft vanwege die beperkte capaciteit ook al preventief vluchten moeten annuleren". But I accept your statement that it means nothing, except for the affected passengers!
Obviously the affected passengers won't be looking at Av24, but I guess those who read this website/forum are interested in having the details. Unless I'm totally wrong; is this website another RTL or HLN buzz stuff but only related to aviation?
2 runways closed, yes, but they have enough runways left; unless the winds make their use impossible and it seemed to be the case for the peak hours this morning.
SN3841(OO-TCH) turned back to BRU while over the France/Spain border. Now back en route to RAK.
Cause of the incident?
I asked Kim Daenen, head of communication department of Brussels Airlines. Here is her answer:
During flight SN3841 there was an indication in the cockpit that the voice and data recorder of the aircraft was not operational, so the aircraft returned to Brussels, where the defect was repaired. 1h10 later, the flight took off again and arrived in Marrakesh with 4h delay. There were 109 passengers on board.
I guess 109 very unhappy passengers....sn26567 wrote: ↑02 May 2022, 15:23I asked Kim Daenen, head of communication department of Brussels Airlines. Here is her answer:
And mostly an equal number of more unhappy passengers having to wait at the airport in RAK, and arriving at 3 am instead of 11 pm....
I guess the data and voice recorders are on the minimum safety list, but couldn't this be fixed on another airport, without having to return all the way to Brussels? Of course, the answer will be that it's normal to fix this at the home base, but the wasted fuel and hours of the crew will have to be taken into account too?
Duke
LOT Boeing 737-800 registered SP-LWA performing flight #LO433 from Warsaw EPWA to Madrid LEMD turned back to WAW due to bomb threat. Aircraft was escorted by two scrambled Polish MiG-29 fighters.
British Airways flight #BA558 from London LHR to Rome FCO (Airbus A320 reg. G-EUYM) is declaring an emergency and diverts to Paris CDG.
