Crashes and serious incidents/accidents in 2019
Re: Crashes and serious incidents/accidents in 2019
A Delta Air Lines Boeing 757 heavily damaged after a hard landing in Ponta Delgada (Azores)
https://www.aviation24.be/airlines/delt ... da-azores/
19 Aug 2019, 21:24
On the day Embraer celebrates its 50th anniversary...
19 Aug 2019, 21:30
19 Aug 2019, 21:24
On 21 August, a Cessna private jet (registration currently unknown) aborted take-off at Oroville Airport, California, United States and went off the runway into dry grass while bursting into flames. Two pilots and eight passengers – with minor injuries only – were able to safely evacuate the aircraft.
https://www.aviation24.be/airports/orov ... to-flames/
SR20 wrote:
15 Aug 2019, 11:32
Russian jet crash-lands in field outside Moscow after striking flock of gulls
https://www.cnn.com/2019/08/15/europe/r ... index.html
Ural Airlines Airbus A321 (VQ-BOZ, msn 2117) was declared a write-off after the cornfield landing near Zhukovsky Airport on 2019-08-15 and the process of dismantling and parts removal has begun.
Seven dead, including two children, after a helicopter and a small plane collide in Mallorca.
https://www.aviation24.be/miscellaneous ... -mallorca/
R.I.P.
KJK
Post by KJK »
A small sport plane has crashed this afternoon around 16.20h at KJK / Kortrijk-Wevelgem airport.
According the press one person did not survive the crash.
Source: WTV https://www.focus-wtv.be/nieuws/vliegtu ... -overleden
Would be MS893 OO-VON. 1 victim indeed. RIP.
Also on https://www.vrt.be/vrtnws/nl/2019/08/27 ... het-leven/
KJK wrote:
27 Aug 2019, 16:55
Basic info with references:
https://aviation-safety.net/wikibase/228549
Caribbean Saab 340 suffers runway excursion during takeoff from Argyle International Airport in St. Vincent and the Grenadines. No injuries reported.
Well done, Sharm el Sheikh ground troops!
Goma (D.R. Congo): crash of an aircraft onto houses - failed take off:
https://actualite.cd/2019/11/24/goma-cr ... e-busy-bee
First reports (which are usually wrong in the DRC): "16 pob".
24 Nov 2019, 10:19
JACDEC confirms: "Busy Bee Congo Dornier Do-228 crashes into houses after take-off from Goma Airport (FZNA), DR Congo with 17 occupants on board. The numbers of fatalities and possible survivors are sketchy at the time."
Never ceases to bewilder me how certain countries seem to be inviting disasters like this by allowing housing so nearby, and on the runway axis. Quite common in Africa, but Californians are good at it, too. Accidents waiting to happen, sadly.
24 Nov 2019, 11:25
24 Nov 2019, 10:19
Reg is 9S-GNH.
Aviation Herald: "...One version of the load sheet identifies 7 passengers, another version 13 passengers..."
http://avherald.com/h?article=4cfb0485&opt=0
Rescue mission ended.
25 Fatalities: 16 pax + 2 crew + 7 local victims.
I'm Thibault Lapers, spotter in Belgium for now 3 years, but not yet across the world and a huuuuuge aviation geek ! Join me on Facebook & Twitter @TLspotting
