Crashes and serious incidents/accidents in 2019
Re: Crashes and serious incidents/accidents in 2019
A Delta Air Lines Boeing 757 heavily damaged after a hard landing in Ponta Delgada (Azores)
https://www.aviation24.be/airlines/delt ... da-azores/
On 21 August, a Cessna private jet (registration currently unknown) aborted take-off at Oroville Airport, California, United States and went off the runway into dry grass while bursting into flames. Two pilots and eight passengers – with minor injuries only – were able to safely evacuate the aircraft.
https://www.aviation24.be/airports/orov ... to-flames/
Ural Airlines Airbus A321 (VQ-BOZ, msn 2117) was declared a write-off after the cornfield landing near Zhukovsky Airport on 2019-08-15 and the process of dismantling and parts removal has begun.SR20 wrote: ↑15 Aug 2019, 11:32Russian jet crash-lands in field outside Moscow after striking flock of gulls
https://www.cnn.com/2019/08/15/europe/r ... index.html
Seven dead, including two children, after a helicopter and a small plane collide in Mallorca.
https://www.aviation24.be/miscellaneous ... -mallorca/
R.I.P.
R.I.P.
A small sport plane has crashed this afternoon around 16.20h at KJK / Kortrijk-Wevelgem airport.
According the press one person did not survive the crash.
Source: WTV https://www.focus-wtv.be/nieuws/vliegtu ... -overleden
Would be MS893 OO-VON. 1 victim indeed. RIP.
Also on https://www.vrt.be/vrtnws/nl/2019/08/27 ... het-leven/
Basic info with references:KJK wrote: ↑27 Aug 2019, 16:55A small sport plane has crashed this afternoon around 16.20h at KJK / Kortrijk-Wevelgem airport.
https://aviation-safety.net/wikibase/228549
Caribbean Saab 340 suffers runway excursion during takeoff from Argyle International Airport in St. Vincent and the Grenadines. No injuries reported.
Well done, Sharm el Sheikh ground troops!
Goma (D.R. Congo): crash of an aircraft onto houses - failed take off:
https://actualite.cd/2019/11/24/goma-cr ... e-busy-bee
First reports (which are usually wrong in the DRC): "16 pob".
JACDEC confirms: "Busy Bee Congo Dornier Do-228 crashes into houses after take-off from Goma Airport (FZNA), DR Congo with 17 occupants on board. The numbers of fatalities and possible survivors are sketchy at the time."Passenger wrote: ↑24 Nov 2019, 10:19Goma (D.R. Congo): crash of an aircraft onto houses - failed take off:
Never ceases to bewilder me how certain countries seem to be inviting disasters like this by allowing housing so nearby, and on the runway axis. Quite common in Africa, but Californians are good at it, too. Accidents waiting to happen, sadly.
Reg is 9S-GNH.sn26567 wrote: ↑24 Nov 2019, 11:25JACDEC confirms: "Busy Bee Congo Dornier Do-228 crashes into houses after take-off from Goma Airport (FZNA), DR Congo with 17 occupants on board. The numbers of fatalities and possible survivors are sketchy at the time."Passenger wrote: ↑24 Nov 2019, 10:19Goma (D.R. Congo): crash of an aircraft onto houses - failed take off:
Aviation Herald: "...One version of the load sheet identifies 7 passengers, another version 13 passengers..."
http://avherald.com/h?article=4cfb0485&opt=0
Rescue mission ended.
25 Fatalities: 16 pax + 2 crew + 7 local victims.
I'm Thibault Lapers, spotter in Belgium for now 3 years, but not yet across the world and a huuuuuge aviation geek ! Join me on Facebook & Twitter @TLspotting
