Crashes and serious incidents/accidents in 2019
Re: Crashes and serious incidents/accidents in 2019
Post by sn26567 » 18 Aug 2019, 22:17
A Delta Air Lines Boeing 757 heavily damaged after a hard landing in Ponta Delgada (Azores)
https://www.aviation24.be/airlines/delt ... da-azores/
Post by luchtzak » 19 Aug 2019, 07:50
Post by luchtzak » 19 Aug 2019, 21:24
Post by Passenger » 19 Aug 2019, 21:30
19 Aug 2019, 21:24
On the day Embraer celebrates its 50th anniversary...
Post by Passenger » 19 Aug 2019, 22:46
19 Aug 2019, 21:30
19 Aug 2019, 21:24
Post by luchtzak » 22 Aug 2019, 12:51
On 21 August, a Cessna private jet (registration currently unknown) aborted take-off at Oroville Airport, California, United States and went off the runway into dry grass while bursting into flames. Two pilots and eight passengers – with minor injuries only – were able to safely evacuate the aircraft.
https://www.aviation24.be/airports/orov ... to-flames/
Post by sn26567 » 23 Aug 2019, 23:18
SR20 wrote:
15 Aug 2019, 11:32
Russian jet crash-lands in field outside Moscow after striking flock of gulls
https://www.cnn.com/2019/08/15/europe/r ... index.html
Ural Airlines Airbus A321 (VQ-BOZ, msn 2117) was declared a write-off after the cornfield landing near Zhukovsky Airport on 2019-08-15 and the process of dismantling and parts removal has begun.
Post by sn26567 » 25 Aug 2019, 18:42
Seven dead, including two children, after a helicopter and a small plane collide in Mallorca.
https://www.aviation24.be/miscellaneous ... -mallorca/
R.I.P.
KJK
Post by KJK » 27 Aug 2019, 16:55
A small sport plane has crashed this afternoon around 16.20h at KJK / Kortrijk-Wevelgem airport.
According the press one person did not survive the crash.
Source: WTV https://www.focus-wtv.be/nieuws/vliegtu ... -overleden
Post by jan_olieslagers » 27 Aug 2019, 18:12
Would be MS893 OO-VON. 1 victim indeed. RIP.
Also on https://www.vrt.be/vrtnws/nl/2019/08/27 ... het-leven/
Post by Passenger » 27 Aug 2019, 18:24
KJK wrote:
27 Aug 2019, 16:55
Basic info with references:
https://aviation-safety.net/wikibase/228549
Post by luchtzak » 27 Aug 2019, 21:34
Caribbean Saab 340 suffers runway excursion during takeoff from Argyle International Airport in St. Vincent and the Grenadines. No injuries reported.
Post by luchtzak » 04 Sep 2019, 12:45
Post by Passenger » 10 Nov 2019, 15:43
Well done, Sharm el Sheikh ground troops!
Post by Passenger » 24 Nov 2019, 10:19
Goma (D.R. Congo): crash of an aircraft onto houses - failed take off:
https://actualite.cd/2019/11/24/goma-cr ... e-busy-bee
First reports (which are usually wrong in the DRC): "16 pob".
Post by sn26567 » 24 Nov 2019, 11:25
24 Nov 2019, 10:19
JACDEC confirms: "Busy Bee Congo Dornier Do-228 crashes into houses after take-off from Goma Airport (FZNA), DR Congo with 17 occupants on board. The numbers of fatalities and possible survivors are sketchy at the time."
Post by jan_olieslagers » 24 Nov 2019, 11:42
Never ceases to bewilder me how certain countries seem to be inviting disasters like this by allowing housing so nearby, and on the runway axis. Quite common in Africa, but Californians are good at it, too. Accidents waiting to happen, sadly.
Post by Passenger » 24 Nov 2019, 11:48
24 Nov 2019, 11:25
24 Nov 2019, 10:19
Reg is 9S-GNH.
Aviation Herald: "...One version of the load sheet identifies 7 passengers, another version 13 passengers..."
http://avherald.com/h?article=4cfb0485&opt=0
Post by Passenger » 24 Nov 2019, 14:21
Rescue mission ended.
25 Fatalities: 16 pax + 2 crew + 7 local victims.
Post by TLspotting » 24 Nov 2019, 17:48
I'm Thibault Lapers, spotter in Belgium for now 3 years, but not yet across the world and a huuuuuge aviation geek ! Join me on Facebook & Twitter @TLspotting
