BrightCedars
Post by BrightCedars »
BrightCedars wrote: 14 Mar 2019, 13:21 Brussels Airlines, a.k.a. Eurowings will get a shitload of used A330s it seems. I just hope that LH Group will take this into account when they compare the efficiency and returns of each component in the group. SN/EW may very well use BRU as a hub for long-haul flights but that doesn't seem to be a priority, although that would be a good way to hit at other low cost operators such as Norwegian. Of course it'll also hit at the established less efficient historical network carriers of which LH is an example. A bit of a schizophrenic situation if you ask me, and that doesn't bode too well for the future.
Somewhat reassuring news at https://www.7sur7.be/7s7/fr/1536/Econom ... ines.dhtml stating that SN result is positive but of course shall improve.
CTBke
Post by CTBke »
sn26567 wrote: 14 Mar 2019, 14:31
CTBke wrote: 14 Mar 2019, 13:45
Omychron wrote: 08 Mar 2019, 14:49
Foreseen to enter DUS operation before the end of March.
Will be operating for SN first until it goes to EW DUS
In EW colours? It would not be a first...
just like SFJ last year
Citybird
The flying dream
Matt
Post by Matt »
Not necessarily a problem tough. the used A330's are all maximum 10y old so it seems with quite efficient Trent 700 engines. Not only that: Brussels Airlines doesn't really has flights of 11+ hours. The A330's are perfect.
A350's is overkill for Brussels Airlines. The B787-8 however would fill in some niches for Brussels Airlines tough...
I would be more worried if Brussels Airlines got the old 767's or 777's of Austrian.... Or even worse: Lufthansa's written A340's ( both 300 and 600's )
Trust me, there are some A340-600's of Lufthansa in the dessert right now, ready to be written of. They could have given it to Brussels airlines to destroy Brussels Airlines
Matt
Post by Matt »
Matt wrote: 14 Mar 2019, 15:24
I would be more worried if Brussels Airlines got the old 767's or 777's of Austrian.... Or even worse: Lufthansa's written off A340's ( both 300 and 600's )
Maybe I was a bit to quick with my reaction yesterday.
OS of course is in much bigger need of new equipment since their 767/777 are way older then SN's incoming A330-fleet, besides these fairly young birds are quite sufficient for SN ops...
And LH wanting to get rid of thirsty A340's seems logical as well. A replacement with A350 is the logical consequence then.
I am just hoping for some positive news for SN at BRU as well...
I thought that the 346 would have been a perfect plane for Brussels Airlines it's true it consumes a lot but it can take a lot of cargo(payload)also perfect for their African market.
But I do not have the experience to judge it.
And it also depends on the lease price I suppose?
CTBke
Post by CTBke »
lumumba wrote: 14 Mar 2019, 18:57
It's the worst plane for SN ... remember the hifly they got last minute .. it got stuck on the runway cause it couldn't turn ... it's too long and some African destinations have the runway as taxiway where they have to make a full turn so in terms of planes this isn't the best plane for SN but the A330 still is
Citybird
The flying dream
Matt
Post by Matt »
Conti764 wrote: 14 Mar 2019, 18:25 Maybe I was a bit to quick with my reaction yesterday.
Hoping for a B787-8 in Brussels Airlines colors ;) #FingersCrossed
Post by Stij »
Let me be the Devil's advocate...
Please stick to A330-300's even if they're second hand until the fleet is at least 20 aircraft, then start thinking about a second type.
Brussels Airlines is dominated by Germans, so the only option to see a 787 with Belgian reg with LH is with Eurowings...
OO-SFK being baptized "Belgian" today: it's on its way to Dakar as SN203 for its first revenue flight under the EW livery.
TLspotting wrote: 16 Mar 2019, 13:32 Brussels Airlines is dominated by Germans, so the only option to see a 787 with Belgian reg with LH is with Eurowings...
Not going to happen any time soon...
BrightCedars
I didn't mean it as a problem, the A330 can offer a very comfortable ride and I agree that SN doesn't have +11hrs destinations for now. Nor could they with this fleet if they wanted to...
Matt
Post by Matt »
BrightCedars wrote: 19 Mar 2019, 10:08
An a330-200 has a range of 13400km... Technically it's possible...
Post by Stij »
I flew a DL A330-300 brom AMS to LAX...
Stij wrote: 19 Mar 2019, 14:57 I flew a DL A330-300 brom AMS to LAX...
I'm not sure al the A330 have the same capabilities for example SFO,M,N did not have this capability!
Post by Stij »
lumumba wrote: 19 Mar 2019, 16:12 I'm not sure al the A330 have the same capabilities for example SFO,M,N did not have this capability!
For sure! But on March 14th the flight was performed by N814NW, an aircraft delivered in 2007...
https://www.flightradar24.com/data/flig ... 9#1fcce447
https://www.airfleets.net/ficheapp/plane-a330-806.htm
So the generation SN is getting now I presume...
DeltaWiskey
Post by DeltaWiskey »
Somewhere from around MSN 500 the standard range capability increased dramatically for the A330-300, at least 1300nm more than the early birds like SFO-M-N-V-W.
SFK (MSN 570) is one of earlier birds that had the increased MTOW modification standard in the production line, up until then it was up to the customer's choice (and wallet).
Much later MSN's also had the option for the activated center tank, giving it almost the same range as the -200's (but with a smaller payload due to the higher OEW).
All of the 'new' A330's will be able to fly ±5000nm with max passenger capacity (no cargo).
Is OO-SFU experiencing problems again? It hasn't flown for more than a week. It has "just" spent over 3 weeks in Lisbon in February (assuming for maintenance).
ezis_bis
Post by ezis_bis »
I saw that 'City of Prague' (OK-NEP) is flying for SN to TLS
Is this plane permanently going to fly for SN? I would find that a bit upsetting, Brussels Airlines with its 'Belgian icon' planes, suddenly flying around with advertisement for another city..
