2017 Liège Airport (LGG/EBLG) latest news
SR20
Re: 2017 Liège Airport (LGG/EBLG) latest news
Post by SR20 »
Acid-drop wrote: 21 Nov 2017, 12:20 So why the delay, I still dont get your last post fredATC
According to "De Tijd", ABC initially planned 12 flight a week. But due to logistics problems at Liège, this number has been reduced to 6.
That's the "delay" ! Actually it's rather a slower start 😉
Ok but too bad there is no explanation.
And its still unclear if they will keep this amount after the klm "deal"...
Clearly this website is on the top of the story.
Russian freighter operator AirBridgeCargo Airlines (ABC) is retaining a significant number of the flights it transferred from Amsterdam Schiphol Airport (AMS) to Belgium’s Liège Airport (LGG) last month despite regaining the slots it had lost at Schiphol.
https://www.lloydsloadinglist.com/freig ... hqjaJ_jLqA
SR20
Post by SR20 »
Re: Trivia 2017 (miscellaneous news)
So not Cat II/III Ops at EBLG for nearly 3 months ?
:shock:
A3431/17 NOTAMN
Q) EBBU/QIUCG/I /NBO/A /000/999/5038N00527E005
A) EBLG B) 1711091630 C) 1801311530 EST
E) ILS RWY 22L DOWNGRADED TO CAT 1
CREATED: 09 Nov 2017 13:25:00
SOURCE: EUECYIYN
SR20
Post by SR20 »
Homo Aeroportus wrote: 30 Nov 2017, 13:02 So not Cat II/III Ops at EBLG for nearly 3 months ?
:shock:
A3431/17 NOTAMN
SOURCE: EUECYIYN
Cat II/III ops are possible on RWY 04R now 😉
FredATC wrote: 30 Nov 2017, 14:00
:shock:
A3431/17 NOTAMN
SOURCE: EUECYIYN
Yeah, but the local potentate doesn't have the same power as others to control the winds and determine the RWY in use ...
EBLG 301520Z 24012KT 9999 -RA BKN010 02/01 Q1003 TEMPO 1000 SHSN BKN002
I seem to remember that the ILS for 22L at EBLG was recently renewed. As such, a trial (verification) period might be necessary before utilising the system for CAT II/III approaches.
SR20
Post by SR20 »
KriVa wrote: 30 Nov 2017, 17:56 I seem to remember that the ILS for 22L at EBLG was recently renewed. As such, a trial (verification) period might be necessary before utilising the system for CAT II/III approaches.
Correct. The new ILS on rwy 22L has to radiate 720 hours without major issues before beeing certified for CAT II/III operations. That brings us till mid-january 2018.
FredATC wrote: 30 Nov 2017, 19:19
Thanks KriVa and FredATC, I learned something (which makes this part of the forum interesting ;) ).
It looks like though that they will test it for more than 720 hours, or they do not operate it continuously. This also explains the odd end date of the NotAm : 31st of Jan at 15:30 !
Let's hope that the Wx remains clement.
Many years ago when EBCI was not properly equipped, my flight had to divert to EBLG. Landing was just into Cat III, an "interesting" experience.
Regarding the 720 hours:
There’s probably some leeway calculated in for downtime, maintenance, other runway configurations etc.
Better to overestimate the time required and cancel the NOTAM early, than the other way around, I would say.
SR20
Post by SR20 »
KriVa wrote: 30 Nov 2017, 22:37 Regarding the 720 hours:
Specially at Liège : most of the time on weekdays RWY 22L is closed for works and 22R is in use. And as ILS 22L and 22R share the same frequency, it's impossible to keep the ILS 22L on the air !
SR20
Post by SR20 »
Homo Aeroportus wrote: 30 Nov 2017, 17:02
That's what's happening tonight !
EBLG ATIS U 2220Z
EBLG INFO,
EXP VECT FOR ILS APP ARR RWY04R DEP RWY04R
RSCD RWY04R WET TL FL050 LVP INPR. NO RIGHT TURN ON TWY A FM TWY S3. TWY S3, N1, N3, N4, C1, C3 AND C4 NOT AVBL
290/3KT VRB BTN 260 AND 340 VIS 200M RVR RWY04R 900M 750M 700M FG FBLSG BKN100FT
T0 DP0 QNH 1005HPA
NOSIG
CONFIRM ATIS U
Could it be this is the reason why ABC delayed the move of some flights ?
Does it reduce capacity by forcing more time between rotations ?
SR20
Post by SR20 »
Acid-drop wrote: 01 Dec 2017, 09:50 Does it reduce capacity by forcing more time between rotations ?
What is a fact is that B748 reduce airport capacity at Liege ! 😂
And this is not a joke. As Liege is not certified for code F aircraft, a special procedure has been implemented to accomodate the B748. The latter can reduce drastically the airport capacity !
The funny part is that nothing is foreseen for Antonov 124 (code F as well, even larger than the B748), a regular visitor of Liege Airport 😧
The mind boggles when one starts considering how little “journalists” know about aviation.
Acid-drop wrote: 10 Dec 2017, 22:13 Boeing 747 vs. Cessna Citation
http://siamagazin.com/boeing-747-vs-ces ... of-my-way/
1,000,000 YouTube views for a private jet taking off before a 747 :roll:
Scoop from pagtour : LGG is in discussion with Ryanair
http://pagtour.info/ryanair-va-sinstaller-a-liege/
https://www.aviation24.be/airlines/ryana ... gian-base/
Very strange thing: LGG was always a good option for low cost companies but the (politic) rule in Wallonia was clear: all cargo in LGG, all pax in CRL, with very few exceptions.
For those unaware this is a very common situation in Wallonia, despite the fact that Liège is a much bigger economic center than Charleroi, the population (the voters) can bias the balance quite intensively.
If Ryanair can come now it can only be for 2 reasons : CRL is full and/or long haul projets.
