With all due respect Sean, but you clearly have no idea whatsoever what you're talking about.sean1982 wrote:you're short term memory is lacking as YOU were the one who drew up the comparison in the first place. Every person killed is one to many no matter whether it is in BRU or in IST or in any other place in the world for that matter. The conclusions you draw in regards to my statement are wrong, false and completly unacceptable as are half of your posts.
Here's what happened: Flanker2 made the incredibly nasty and malicious comment that BRU should be ashamed of itself because it took so long to reopen the airport while in IST they reopened much sooner. Passenger responded to that with a clear and concise explanation as to why that was the case. At NO point did Passenger show even any semblance of disrespect to the victims at either airport, and he most certainly at no point said or implied that victims at either airport are more or less valuable than the other. That's just what you appear to have dreamed up in your head, in an attempt to make that ridiculous feud you've got going on with Passenger flare up again. Your posts on this are WAY out of line, Sean. Check yourself.
