original Dutch text:
Op vliegveld Eelde nabij Groningen is een passagiersvliegtuig van Onur Air bij het opstijgen in de problemen geraakt. Het toestel met bestemming Turkije kwam bij het opstijgen niet van de grond en schoot door.
De 140 passagiers hebben het toestel ondertussen kunnen verlaten. Een aantal reizigers is met knie- en rugklachten behandeld. De hulpverleningsdiensten hebben groot alarm geslagen, en worden bij gestaan door de brandweer van de gemeente Eelde.
Volgens ooggetuigen was er bij het opstijgen van het vliegtuig rook te zien. Om 11:30u is een persconferentie.
English Translation:
In Eelde (Nl), an Onur air passengers plane overshot the runway while trying to take off. 140 passengers were evacuated, some of them with knee and back problems. more information on a press conference at 11:30 local time. Eye witnesses reported smoke during the take off trial.
Passenger plane aborting takeoff at Eelde (NL)!
gear collapsed, luckily rear mounted engines
According to the picture, the MD-88 seems to have sunk through his landing gear while rolling in the soft grass... I guess they're lucky that it was a MD-88 and not a Boing, Airbus or RJ with wing-mounted engines... could have been more catastrophic.
SAB-OM
Here is a topic about the AA89.
Not only the braking blocks needed to be replaced also most of the tires.
Greetz,
Dave
Greetz,
Dave
- Sabena_690
I have been on TC-ONP twice (BRU-ADB-BRU), and I have to say that I was extremely disspointed with it's climb performance. In Brussels, it needed the same runway lenght (with maximum thrust) as a fully loaden B747, and the same happened when we took off in ADB.
In comparision: a year later I flew 3 times on an MD82 of AZ, and those climbed like rockets.
Glad that nobody is injured!
Regards
Frederic
Regards
Frederic
Hi all,
a picture of the Onur Air MD 80 can be found at http://www.planepictures.net/netshow.cgi?111469
Slides deployed and overwing exits used.
ciao,
Bart
ciao,
Bart
You can see also the photos of the recovery on www.planepictures.net (search for TC-ONP) or on www.jetstar.nl
Greetz
Dave
Greetz
Dave
