Boeing 777(X) news
Re: Boeing 777(X) news
sn26567 wrote: 11 Mar 2022, 16:15 FAA is finalising three safety directives for some grounded Boeing 777 planes with P&W 4000 engines that will allow them to return to service.
United Airlines doesn’t expect to fly dozens of B777s, grounded more than a year ago after one suffered an engine failure, until at least mid-May 2022.
Boeing is preparing for a new delay in the B777X programme that would push first deliveries by at least a year into early 2025.
sn26567 wrote: 25 Apr 2022, 17:42 Boeing is preparing for a new delay in the B777X programme that would push first deliveries by at least a year into early 2025.
Emirates president Tim Clark does not expect the airline to receive its first B777-9 before 2025. The carrier will refurbish more of its existing fleet than previously planned, including 120 aircraft from its existing fleet of A380 and B777.
Air Lease Corp. chairman Steven Udvar-Hazy said the future of the B777X project could be at risk after Boeing pushed back the first delivery of the aircraft by more than a year to 2025.
Lufthansa Group has ordered a total of ten freighters – including three B777F and seven B777-8F, In addition, leases for two B777Fs, which run through 2024, will be extended for seven years each through 2031. The first of the B777F is expected as early as July 2022 and delivery of the -8Fs is expected at a later date between 2027 and 2030.
https://www.aviation24.be/airlines/luft ... reighters/
sn26567 wrote: 11 Apr 2022, 16:17
United Airlines said that the FAA has cleared the path for the return of 52 P&W-powered Boeing 777s that were grounded after an engine failure in February 2021.
ANA All Nippon Airways resumed operation of the B777 equipped with PW4000 engines. All the grounded B777s will return to operations by October 2022.
sn26567 wrote: 23 Jun 2022, 22:15 ANA All Nippon Airways resumed operation of the B777 equipped with PW4000 engines. All the grounded B777s will return to operations by October 2022.
ANA All Nippon Airways (Japan) has resumed operations with its PW4000-powered B777s. Eight of the aircraft will return in August 2022. It is expected that the maintenance of all 15 aircraft will be completed by the end of October 2022.
Boeing has temporarily suspended B777-9 test flights pending joint investigations with GE Aerospace into an unspecified issue on the aircraft’s GE9X engine.
