For the growth of the short/medium haul fleet, I don't see SN take new a319/a320 this year on it's own. They are too cautious for that. If it was the case they would be hiring more crew than what they do now.
What I would rather see would be a wetlease within the group as many aircraft are still unused or maybe a wetlease with what seems to be a new friend of the group, Air Baltic with A220-300.
Brussels Airlines' fleet renewal
Re: Brussels Airlines' fleet renewal
Repainting an aircraft is not like repainting your bedroom ... just an idea about the steps:longwings wrote: ↑08 Jan 2022, 18:12 Repainting an A320x costs approx. $50-60,000 per American Airlines. Deadheading a crew is a marginal cost by comparison.
If the goal was to maximize savings, Brussels Airlines would schedule the next aircraft to be painted on the evening BRU-LHR, then ferry the plane empty to EMA overnight, and bring a freshly painted aircraft back to LHR in time for the morning flight to BRU.
1) mounting of scaffolding
2) cleaning off old paint
3) applying a primary color and letting it dry
4) applying base color and letting it dry
5) applying custom made paint and letting it dry
6) unmounting scaffolding
All this in overnight ? Try it at home first and let me know what it gives
I think that he meant that the pilots that arrive in EMA in the evening with the plane that has to be painted can leave the next morning with the previous plane.RedNose wrote: ↑11 Jan 2022, 15:14Repainting an aircraft is not like repainting your bedroom ... just an idea about the steps:longwings wrote: ↑08 Jan 2022, 18:12 Repainting an A320x costs approx. $50-60,000 per American Airlines. Deadheading a crew is a marginal cost by comparison.
BRU-LHR-EMA-waiting time-LHR-BRU
So if I understand well, the suggestion would be to do a 4-stretch-13hours-night duty?
Well, that is why it costs $50k.... lots of industrious elves, magical paint, and a time-suspension machine. At least that's how it works when I repaint my bedroom.RedNose wrote: ↑11 Jan 2022, 15:14All this in overnight ? Try it at home first and let me know what it giveslongwings wrote: ↑08 Jan 2022, 18:12 Repainting an A320x costs approx. $50-60,000 per American Airlines. Deadheading a crew is a marginal cost by comparison.
I will let you re-read what I wrote around crewing these flights and then let you come to your own conclusions around your... understanding.
Well I did, but unfortunately you talk about the aircrafts and flights but don't talk about your genious idea to crew them. Why making complicated when you can do simple. Anyway.
Seems this went unnoticed...
But last tuesday, 8-2, OO-SSM, the final aircraft in the fleet with a tie to the old Sabena, took off for her final flight to St. Athan.
OO-SSH Just did its first take off in two years.
Has someone any info on OO-SNO? It was suppose to join the fleet in june, but we know nothing so far, from where it comes from etc.
Just a little hint regarding OO-SNO, there where a ferry flight Pegasus Airlines from Istanbul to Brussels yesterday
OO-SNO will be MSN 3831
I hope this one will get the SN colors and not the EW like OO-SNN ?
It will start flying in September, it will be retrofitted and repainted in october
Is the repaint process (+ retrofit) of the fleet still under progress ? Where are we standing now ?
You can best follow this here:
https://sites.google.com/view/europeanairlinefleets/bel
Currently 11 are painted in the new schema (7 A319, 3 A320 and 1 A330) - White with blue symbol for the plane
I guess they do not repaint now, usually that is more done in the winter season for the obvious reason ...
D
D
What is the timeline of upgauging from 319 to an all 320 fleet on shorthaul routes?
No, only 2 A320's, OO-SNO is at the moment full white and due to repaint around october/novemberDannyVDB wrote: ↑04 Sep 2022, 11:17 You can best follow this here:
D
Why not beginning by the A320 which still is in EW colors ?
Often livery updates and maintenance go hand-in-hand. Less disruptive from a network scheduling perspective to take an aircraft out of service for paint and C/D checks together - even if done at separate facilities - than scheduling two down times separately, one for paint the other for maintenance. Maybe the Eurowings aircraft are not due for maintenance yet.brusselsairlinesfan wrote: ↑10 Sep 2022, 11:59 Why not beginning by the A320 which still is in EW colors ?
Even if the decision is made to separate paint from maintenance (new livery needs to go on asap, scheduling can't afford to have the plane out for paint and maintenance, etc.), still have to make sure enough planes are available to operate the schedule. Can't repaint an Eurowing aircraft if another aircraft is already out for planned maintenance and the schedule can't afford two planes out of service.
Age of livery is also a factor. When not during maintenance, aircraft with an older livery tend to be repainted earlier than aircraft with a newer one.
Finally cost vs lifespan is a factor. Aircraft within one-to-two years of fleet exit typically do not get repainted bc not worth the cost, unless the livery is really showing its age. Not sure that applies to Brussels' A320 in Eurowings livery though.
Meanwhile SFJ (so-called spare A330) went to Amman on Monday 19th. This seems to be in line with daily reduction of lh flights; eg: IAD flights have been discontinued since that day; winter season starting already?
Unbelievable that a home carrier discontinued flights between the two major diplomatic cities in the world. OK, most of them are using UA but still there is always space for that extra flight
