Hello,
Royal Air Maroc B747-400
06.45-08.25 AT 842/841 TNG-BRU-NDR
Tunisair A300
10.40-11.45 TU 788/789 TUN-BRU-TUN
Again Royal Air Maroc B747-400
15.40-??? AT 840/??? NDR-BRU-???
Kristof
BRU 17/07/2007
Forum rules
viewtopic.php?f=21&t=12716
- Bruspotter
I've done a search, maybe I didn't look good enough, but to me it only seems that there is an irregularity in the Brussels Airport's timetable.
As I remember from other summers it should be like this:
ARR 06:45 AT 842 from Tangier
DEP 08:25 AT 841 to Nador
ARR 15:40 AT 840 from Nador
DEP 17:35 AT 843 to Tangier
about the departure time to Tangier I'm not really sure, it's a guess based on the ETD from last summer, but I do know that he goes back to Tangier.
Anyone to confirm?
Best regards: Yannick
Anyone to confirm?
2 years ago on 14 July I saw F-16s, C-130s and the A310 of Belgian Air Force overflying the Berlaymont.blackhawk wrote:Just seen @ 16:20: F16 overflying Brussels-Noord / Center . Also other military aircrafts are overflying brussels ... 21 july is coming closer ....
It was very nice to see due to very hot weather and the bright blue sky.
- Established02
- Tompompier
Sometimes planes are parked 90degrees clockwise due to the winds at that moment.Established02 wrote:Today's KE 744F got parked 90 degrees clockwise to its normal parking position.
The nose cargo door got opened, but that by itself is nothing extraordinary.
The aircraft spent about 4 hours on the ground and took a delay of 1h30.
Anyone knows what was special about today's load?
Tompompier
- Bruspotter
- Established02
You are right.Tompompier wrote:Sometimes planes are parked 90degrees clockwise due to the winds at that moment.Established02 wrote:Today's KE 744F got parked 90 degrees clockwise to its normal parking position.
However, I believe today's wind conditions were not of a kind to take these special safety measures.
An OZ 744 and SV 742 came in after the KE 744, but they parked in the regular manner, just like all the other cargo aircraft today.
- Tompompier
Don't know the situation today, because I was not at work today.Established02 wrote:You are right.Tompompier wrote:Sometimes planes are parked 90degrees clockwise due to the winds at that moment.Established02 wrote:Today's KE 744F got parked 90 degrees clockwise to its normal parking position.
Tompompier
