A 737-300 of TNT made an emergency landing in BHX this morning.
The plane came from Liège/Bierset.
No injuries reported.
Any info about the registration?
Cheers
Olivier
TNT accident in BHX/Birmingham U.K.
Apparently they closed the runway as they foamed the runway.
Article can be found here: http://www.24dash.com/content/news/view ... ewsID=6918
- Advisor
Why did they foam the runwayteddybAIR wrote:Apparently they closed the runway as they foamed the runway.
Was there a spill
Aum Sweet Aum.
- speedbird1
Possibly a small fire or hot metal, due to metal hitting runway at 140 kts ish! Not a good mix.Advisor wrote:Why did they foam the runwayteddybAIR wrote:Apparently they closed the runway as they foamed the runway.
Was there a spill
Emirates
A/c was due for landing at MME. During CatIII approach, autopilot was disengaged on short final. A/c slammed into runway, thereby ripping off RH LDG. The gear then slammed into the inboard flaps and aft fuselage.
Go-around initiated and after being airborne again, crew requested emergency landing at BHX due to weather conditions.
Krgds,
GR.
Krgds,
GR.
Was there a spill
Advisor, when you shave dry, it burns, isn't it.
Now when an aircraft makes an emergency landing, and the landing gear collapses, that impact may produce sparks, and if the tanks burst or leak, that may burn too...
It is a precaution.
btw
METAR for MME does not show some particular...
Answered my own question. MME = Durham - Tees Valley (formerly Teeside).
Next question.Why would you then fly all the way to Birmingham when you could go to Manchester (80 miles closer) which has 2 runways so if a problem they could keep flying. Maybe the landing fee is cheaper at Birmingham?
Looks the flight crew will haves some explaining to do!!!
C
C
