Air Seychelles ( IATA: HM, ICAO: SEY ) has 2 Boeing 767-200ER.
They are used on routes to Paris, London Heathrow, Frankfurt, Rome, Zürich and Singapore. They hace a C24Y222 seat lay-out.
When B767-2Q8ER reg S7-AAS was delivered it set a new non-stop distance record for a twin engine commercial plane.
It flew from Michigan to Mahé in 16 hrs and 49 min. a flight of 8893miles or 14311km.
Here S7-AAS named "Aldabra" is being pushed from it's parking at it's homebase Mahé ( SEZ/FSIA )
Air Seychelles
Air Seychelles
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return."
This oneFlyEmirates wrote:Air Seychelles also operate some Shorts SD360's , we fuelled 1 (S7-PAL)
Shorts 360-300 reg S7-PAL named "Ile de Palme"
Air Seychelles has three Shorts 360.
Equipped with PWC PT6A-67R engines and a Y20 seat lay-out.
Before I get comments I want to say that I made a mistake with the name of the airline
I wrote "Aer" instead of "Air"
But I thought it was better to let it stay that way instead of correcting it.
It would make a bad result on the drawing being it already colored.
Thanks for the compliments.Flying_Dutchman wrote: By the way, you have a fantastic avator!!
Made the avatar myself ( drawing )
The original can be seen here.
http://www.airliners.net/open.file/451253/M/
It's taken at EHAM
- B744skipper
