xxxx-0815 F2TH PRJJR
xxxx-1215 CL35 CSCHF
xxxx-1215 E50P 9HLGM
1405-1425 C510 OEFZC
1610-1930 DAF CL60 C080 EBMB
xxxx-1615 E50P 9HFGV
1650-xxxx C510 OEFDT
1635-1915 CEF YK40 0260 EBMB
1655-1755 FA7X OYFFI
1720-xxxx PC24 LXPCC
1730-1925 LJ45 LXEAA
1735-1840 HFM A319 9HXFW EBMB, LFMI-EBMB-LFPG
xxxx-1815 CL60 9HVFC
2035-2130 E50P FHLRZ
2110-xxxx C25M DIFHD
2205-xxxx HFY A343 CSTQZ
Greetings,
BRU 02/02/2020
Forum rules
viewtopic.php?f=21&t=12716
BRU 02/02/2020
Re: BRU 02/02/2020
A 78X is expected for Etihad. No Greenliner in sight.
Re: BRU 02/02/2020
flying on a Danish Air Force? Don't think so
Re: BRU 02/02/2020
A6-BMB it is
Re: BRU 02/02/2020
STA 08:20 LH1004 D-AIEB A321neo
STA 08:35 DL80 N844MH 767-400ER / SkyTeam livery
STA 09:00 UA972 N653UA 767-300ER / Star Alliance livery
Re: BRU 02/02/2020
Rumours now instead of an Airbus A380, it would be an Airbus A319 of Hifly... Any news about?.. Or a BAF Embraer would be used...
Re: BRU 02/02/2020
Whatever aircraft type it will be, it won’t be an A380. Like I said before, EBMB is not capable of accommodating an A380, and for this particular flight, EBMB is the only option.
Re: BRU 02/02/2020
The aircraft could still be handled at EBBR while having destination EBMB. This has happened in the past already. That being said, I have my doubts as well. 9H-MIP is currently on its way to LFMI, no one here who could check if there is a flightplan filed for LFMI-EBMB already?
Maybe to pick up the Danish passengers coming from Istres?
Re: BRU 02/02/2020
That could be the case, but not in this instance, where passengers have to go into quarantine as soon as they step off the plane.
Only EBMB is suitable for that kind of procedure. Hence, no A380.
Re: BRU 02/02/2020
It will be an A340-300 CS-TQZ, filed with an ETA around 2200 from Hanoi, Vietnam as HFY471P.
Re: BRU 02/02/2020
Why a positionning flight number then ? 9HMIP is flying as HFM432...
Re: BRU 02/02/2020
It is, nearly above New Delhi. https://www.flightradar24.com/HFY471P/23bad2b9
Re: BRU 02/02/2020
Updated my list with an A319 coming in from LFMI...
Greetings,
Greetings,
Re: BRU 02/02/2020
That looks like the most probable option for the repatriation of the Belgians from Wuhan.
A380 9H-MIP currently landing at LFMI.
