ATC scanner for contrail?
Planespotting in the upper atmosphere! All pictures, reports or whatever question about upper level traffic come here
dionplanespotter
Post by dionplanespotter »
Hey
I'm looking for a scanner for contrail! My question is: which scanner and how? I have a uniden bearcat ubc125xlt :P
ATC like this: https://www.youtube.com/watch?v=73licCOgnxY
greetings
Dion
leedseagle
Re: ATC scanner for contrail?
Post by leedseagle »
Hi there
Depends how far you live from control centre to hear their messages but planes overhead you should be able to hear with normal antenna if you are lucky enough to live where planes change frequency, if you want to listen to transmissions from further afield you will need an airband dipole antenna to put in your loft
Clear Sky's
Leedseagle
8" Skywatcher Dobsonian, Revelation 2" ED Barlow, Canon EOS 500d, Nikon Coolpix P900, Uniden EZI33XLT, Celestron Skymaster 25x75 Binoculars
http://www.flightradar24.com https://contrailspotting.wordpress.com
What do you think of an App called LiveATC ?
leedseagle
Hi there
LiveATC can be quite hit and miss to have airports/control centres you want
Clear skys
Leedseagle
dionplanespotter
leedseagle wrote:Hi there
Clear Sky's
Leedseagle
Oke How do I get
the frequency?
leedseagle
If your in uk
http://www.jethros.org.uk/scanner/atc_airways.htm
http://www.2e0jps.com/radio/airband/control/
Is where i got all mine
Clear Sky's
Leedseagle
dionplanespotter
leedseagle wrote:If your in uk
Clear Sky's
Leedseagle
oke i live in the netherlands! :|
leedseagle
List of Maarstricht eurocontrol frequencies
http://www.atcbox.com/forum/viewtopic.php?f=5&t=19715
And couple of maps of eurocontrol (sectors/waypoints/frequencies)
http://www.eurocontrol.int/sites/defaul ... 151112.pdf
http://www.eurocontrol.int/sites/defaul ... e-ectl.pdf
I can pick up Amsterdam 123.7 with dipole in my loft as planes fly on UY70 on track to fly over Yorkshire
Hope this helps
dionplanespotter
leedseagle wrote:List of Maarstricht eurocontrol frequencies
Hope this helps
Oh! Thans men! :D
dionplanespotter
Hope this helps
The link of the maps is not working :(
seorm10
Post by seorm10 »
I'm new to scanners and I'm looking for a good scanner for ATC mainly but also police. I'm within 10 miles of Tyndall AFB so I want to hear that or at least Tyndall Center. I'm looking for one at or below $150 I can go over but I'd rather not. I'd prefer handheld. Any help is appreciated.
Arcocox
Post by Arcocox »
Hi, it isnt very big, quite a compact unit, it is a front type ATC.
I will go down the Unit tomorrow and get some measurements for you.
Regards
Rob
