the A340-500 and A330-300 remain my fav. airbus types if its about the looks
face down, ass up!
Airbus A350 XWB news
Re: Airbus A350 news
Airbus confirms that the A350 XWB first flight is planned for this Friday, 14th June, based on current visibility of the programme and the flight test status. Weather conditions permitting, the A350 XWB “MSN1” will take off from Toulouse-Blagnac airport at around 10:00 am local time. Below the satellite transmission parameters to broadcast the signal.
http://www.airbus.com/presscentre/event-information/
On youtube:Passenger wrote:Live coverage today, as from 09h BRU-time (0700 UTC):
http://www.a350xwbfirstflight.com
Tot hier en verder
- BrightCedars
Can anybody tell me if the gear remaining down above the clouds is a standard procedure for a first flight?
Will they test it later in this flight or in another?
- BrightCedars
Seems like the gear has since been raised!
It is indeed standard procedure. They first test the aircraft like this before moving to a full 'clean' config (gear up - flaps up).BrightCedars wrote:Can anybody tell me if the gear remaining down above the clouds is a standard procedure for a first flight?
A350 looks much nicer without the gear, imo
Tot hier en verder
- travellover
Cheers
The first flight seems limited to some 14000 ft. MSN001 will be on the ground for a few days after this flight, then tackle initial high-speed, high-altitude testing during its second flight.
After 3 hours at FL140, MSN001 has climbed to FL250 and accelerated to 490 knots.sn26567 wrote:The first flight seems limited to some 14000 ft.
She's approaching the runway and will land shorly.
On the way to TLS for the low passKriVa wrote:They'll be doing a low pass first)
... and the low pass at 1500 ft over the runway
Pictures Airbus
This second flight is necessary before the Airbus people can think at a fly over the Paris Air Show. Airbus will do everything it can to have the third A350 flight at Le Bourget on Friday, June 21st, when President Hollande will visit the show.sn26567 wrote:MSN001 will be on the ground for a few days after this flight, then tackle initial high-speed, high-altitude testing during its second flight.
On another topic, is there any specialist in our audience who could tell me which type of plastic is used in the carbon-fibre composites that make the structure of the A350 (or in the 787 for that matter) ?
I asked the question when I visited Airbus in Hamburg with the AvGeeks, but the guide refused to answer that question. The types that come to mind are epoxy or polyester, but that's only a guess...
It's a CFRP, Carbon-Fibre Reinforced Polymer. More specificly it's HexPly M21 made by Hexcel.sn26567 wrote: On another topic, is there any specialist in our audience who could tell me which type of plastic is used in the carbon-fibre composites that make the structure of the A350 (or in the 787 for that matter) ?
It's an sort of epoxy reinforced with carbon fibers.
The datasheet: http://www.hexcel.com/Resources/DataShe ... global.pdf
I've just looked through this video from airbus marketing team.. Tremendous pictures of the A350XWB !
http://www.youtube.com/watch?v=7U6IJ-LS3Xs
I wish them great success ..
Oddly this plane reminds me of the DC8.. Don't know why
This link is better:
: http://www.youtube.com/watch?v=DC9qmo7roWc
video of 4 minutes "Best of 14th June":
