Thomas Cook UK 757-300 dropped overwing slide
CTBke
Post by CTBke »
A Thomas Cook Boeing 757-300, registration G-JMAB performing flight MT-1638 from London Gatwick,EN (UK) to Hurghada (Egypt) with 237 people on board, had just reached cruise level 330 about 200nm east of Gatwick Airport and southsoutheast of Brussels (Belgium) when the crew received an abnormal indication and decided to burn off fuel and return to Gatwick Airport. On approach to the airport the aircraft dropped one of the over wing escape slides. The aircraft landed safely back in Gatwick about 2 hours after departure.
The airline reported the crew received indication of a fault with the over wing escape slide and decided to return to Gatwick. The slide separated from the aircraft somewhere along the flight.
Kent Police reported the object is believed to have fallen down between Langton Green and Groombridge, about 15nm east of Gatwick Airport, about 5 to 10 minutes prior to the aircraft landing back in Gatwick.
A passenger reported that shortly after the top of climb (aircraft levelled off after having reached cruise flight) the captain announced a technical fault requiring them to return to Gatwick. The aircraft burned off fuel for about 1.5 hours over the Gatwick and Brighton area. While on following approach to Gatwick Airport a very loud thump sound occurred and something believed to be a panel separated from the aircraft, probably hitting the fuselage and or tailplane. The aircraft touched down safely, stopped at the end of the runway and shut both engines down for an inspection by emergency services.
The AAIB have opened an investigation.
A replacement Boeing 767-300 registration G-POWD is estimated to reach Hurghada with a delay of 7:45 hours.
Source: http://avherald.com/h?article=47c98ac8&opt=0
Citybird
The flying dream
Malaysia
Re: Thomas Cook UK 757-300 dropped overwing slide
Post by Malaysia »
Would be nice if you mentioned the source, avherald.
CTBke
Post by CTBke »
has been edited
Citybird
The flying dream
