Arrival times
08u10 ETH 777 ET-ANR Pax!
10u02 SAM 757 99-0004
10u45 GZP f900 RA-09006
11u21 GAF 319 1502
11u36 SSG TU154 OM-BYO
14u02 OSY an30
BRU 20/03/2015 AN30 + TU154
Forum rules
viewtopic.php?f=21&t=12716
Re: BRU 20/03/2015
The ETH 777-200LR is planned at 09.25 local, as ETH706. Runway in use for landings now is 01.
Re: BRU 20/03/2015
Is ET-AQL from FRAKriVa wrote:The ETH 777-200LR is planned at 09.25 local, as ETH706. Runway in use for landings now is 01.
Has this something to do with the strike at Lufthansa? Maybe they rebooked some passengers on the ET flight..
xxxx-0930 C56X DCAHO
0945-xxxx CL60 N3FE
xxxx-1115 BGF F2TH LZOOI
1120-xxxx GAF 319 1502
1125-2015 F900 RA09006
1130-1345 SSG T154 OMBYO
xxxx-1315 CL60 OHWII
xxxx-1345 CEF 319 2801
xxxx-1345 GAF GL5T 1404
xxxx-1345 SVF GLF4 102004 EBMB
1355-xxxx E55P CSPHA
xxxx-1355 AME F900 T185
1400-xxxx OSY AN30 01 EBMB
xxxx-1415 KRF B461 ZE701
xxxx-1415 RO 310 YRLCB
xxxx-1430 CTM FA7X FRAFA
xxxx-1445 FA7X HBJGI
xxxx-1445 LYF C27J 08
xxxx-1445 LO E170 SPLIH
xxxx-1445 CL60 MASHI
xxxxx-1515 CL60 9ACRO
1530-1830 LJ35 DCEXP
xxxx-1615 LJ60 9HAFJ
1620-1645 C525 DIBAK
ALL TIMES LOCAL
0945-xxxx CL60 N3FE
ALL TIMES LOCAL
Re: BRU 20/03/2015 AN30 + TU154
Qatar Airways B787 A7-BCS (delivered 28FEB2015):
1235-1510 QTR193/194 DOH-BRU-DOH
2 topics for the same date merged.
HiFly Airbus A330-200 CS-TQP:
STA 05.35 as BEL1206 from DKR
TAROM Airbus A310-300 YR-LCA:
STA 18.40 as ROT373 from OTP
STD 19.25 as ROT374 to OTP
