a question for pilots about colour blindness test
guys do anyone knows about the eye colour blindness test for the pilots..is there any pilot there to tell me about the test he or she took? here in egypt we us FAA rules so would like to know if they just do the test as for example showing coloured balls or those plates with the hidden number in? please reply to me because it can full fill my dream to finally be a pilot especially if the test is only about coloured balls or sheets thanks alot in advance
- thomascookie
thanks alot guys.TUB001&TWR.you really made me feel better..no i don`t have a serious ones...i can diffrenciate between them easily except for the numbers and sometimes i get like 2 or3 out of the 8 numbers infront of me i think i should give it a try...anyone knows if i failed the test if i have the right to re do it again or no?&TUB001 was your friend applying to be an airliner pilot?
Yes, the guy I know is currently doing his frozen-ATPL in Canada, so he has the medical class 1 there. It wouldn't have been possible in Belgium though, but as I said, his colour blindness level was *really* serious.sasa wrote:thanks alot guys.TUB001&TWR.you really made me feel better..no i don`t have a serious ones...i can diffrenciate between them easily except for the numbers and sometimes i get like 2 or3 out of the 8 numbers infront of me i think i should give it a try...anyone knows if i failed the test if i have the right to re do it again or no?&TUB001 was your friend applying to be an airliner pilot?
What you can also do is to ask them what the tolerances are and then go for a check at your ophtalmologist. It could avoid you to spend almost 400€ for nothing. I am not sure you can do the test more than once if you are judged unfit for such a reason.
Check on http://mobilit.fgov.be to get some contact information for the Medical Department.
Good luck, and don't give up
