Just seen this pic on planepictures.net and I'm wondering if the aircraft in the picture id dumping a little fuel before landing? The comment doesn't suggest it, but to me it just doesn't tell the full story!
Have a look and see what do you think?
http://www.planepictures.net/netshow.php?id=311605
Emirates
Confusing Picture
I suppose the picture was taken Saturday MAR05?
Afonso Pena Airport is located in Curitiba, Brazil, capital of the State of Paraná, 1.6 million people.
Landing on Runway 2: Heading 15/33, 2,215m (7,267ft), 42/F/A/X/T
This airport elevation is 911m
Then some explanation is here
Weather data for MAR05
Mean Temperature 65 °F / 18 °C
Max Temperature 75 °F / 23 °C
Min Temperature 55 °F / 12 °C
Dew Point 56 °F / 13 °C
Average Humidity 85
Maximum Humidity 100
Minimum Humidity 64
AEROPORTO INTERNACIONAL AFONSO PENA also click: Mais Fotos
Very good observations, Robin.
Note: Lots of people like to speak German there, I remember. I suspect the Germans even to get inspired by the opera there for the design of the parliament house in Berlin...
There I saw capivaras too.
Average Humidity 85
Minimum Humidity 64
- Advisor
What are contrails? This topic can be viewed at
https://www.aviation24.be/posts7748-start20.html
Chemtrails! This can be viewed at
https://www.aviation24.be/postt9132.html
Now we can have a discussion whether it is a contrail or a chemtrail. Though the possibility of a fuel dump also cannot be totally ruled out.
Aum Sweet Aum.
It's not strictly true that dumping fuel from a low level does not happen. Last year whilst in Vancouver I watched an Air Canada A340 take off and as it rotated it blew an engine, very quickly you could also smell fuel, the aircraft declared an emergency and could be seen streaking through the Vancouver skies at 5000ft dumping as much fuel as possible and coming straight back on approach to the same runway and landing within 10mins, still dumping fuel. My photos of this actually appeared on the front cover of the Vancouver Sun newspaper. AND YEP IT STANK TO HELL FOR HOURS AFTER.
Rgds
Tony
Rgds
Tony
Fuel dump definitely.
On DC-10 that's the position of the fuel dump probes.
Indeed weird situation to dump fuel, but actually I find the contrails a little bit too big and dense for regular condensation contrails.
And in my opinion, if the aircraft would leave such big condensation stripes on the outboard flaps, there would also be something visible on the inboard flaps. Go have a look when a DC-10 or MD-11 comes in with moistureous weather and watch the outboard of the inboard flaps.
The fuel dump pipe is placed in such a position that fuel can be diffused as good as possible so that it vaporizes quickly, like near the outboard flap edge where a lot of vortices are created.
My 2 cents
My 2 cents
- speedbird1
Tony,EPS_Aviation wrote:I found my pics of the Air Canada A330 but don't know how to upload them, if someone wants to explain, i'll post them later
these links might help you already:
https://www.aviation24.be/postt4516.html
https://www.aviation24.be/postt494.html
- Bruspotter
Come on, be realistic... that a contrail? Don't think so.
http://www.airliners.net/open.file/322808/L
To me it does toughAvro wrote:To me it doesn't look like fuel dumping....
On the same place as most jetliners have:Avro wrote:I will chack later to see where the Jettison lines are located on the DC-10.
Already checked before I posted.Avro wrote:To me it doesn't look like fuel dumping.... I will chack later to see where the Jettison lines are located on the DC-10.
Are there 2 jettison lines on the DC10 as well ?
2 fuel jettison pipes right outboard of the outboard flaps.
Fuel dump is always massive That's the whole idea of fuel dumping, to loose the fuel as fast as possible.Bruspotter wrote:Wow!!! That would have been some massive fuel dump!
How do you mean? Too long for fuel dump? Sorry if I misunderstand you.Emirates wrote:The trails seem too long
Fuel dump trails are always more intense unless there's no more fuel left to dump. Thus longer and thicker than just floating water which is gathered by the wing. Certainly with such a relatively nice weather. Maybe when it would have been raining.
I've seen DC-10's coming in at Brussels (short final in my garden) with heavy rainfall 100's of times and never saw them with such big water trails.
Can't think of anything else but fuel dump. To me water trail is excluded because of too intense and no trail at the inboard flaps, where there also should have been some trail visible.
