AZ ER7 still coming to BRU?
Glider
Post by Glider »
Is the AZ ERJ-170 still coming to BRU? It did, that I'm sure of, but now...
After some search on the BIAC-site; I could nothing find on this topic...
Someone has the answer? And if it still comes to BRU, which flight does it operate? Is it coming tomorrow (when I will be at the RWY)?
Thx
Glider
Lyulka
Post by Lyulka »
I saw it last friday in the morning. It is operating for Alitalia express, but I don't know which flights...
Robin_Bamps
Post by Robin_Bamps »
I think that there isn't a permanent schedule for the ERJ-170's of AZ. I saw one taking off from 25R on Wednesday morning (01/09).
Just check out the BIAC arrival plans regulary... I'm shure there will be a ERJ-170 operated flight mentioned in the next couple of days.
Regards, Robin Bamps.
The OAG mentions that flights AZ 148/151 (LIN-BRU-LIN arr. 8.40 dep 9.30 Mon-Fri) and AZ 146/149 (MXP-BRU-MXP arr. 11.00 dep. 12.10 Wed & Sun until 12/9) are operated by an E-170.
Glider
Post by Glider »
Jup, tomorrow it's my party...
At least I hope. Hope with me for some 02-landings. I will not make the arrival (8.40), but maybe I will for the departure (9.30). Therefore, I hope they will t/o RWY07R.
Bruspotter
RE: AZ ER7 still at BRU?
Post by Bruspotter »
Hello.
I'm sure he's still operating Brussels frequently,but i don't know
exactely wich days,but i mend Sat and Fri ,that's when i saw him(2 times)
but it could be that the days that he comes to BRU are switched.
Must also say that he operates BRU together with the EMB-RJ145,
wich means it could be that you see a ER4 instead of a E70.
But i can give you the dates when the normal ER4 comes,and probely
one of these days you have the most chance to spot him.
Day ARR DEP Dest/origin valid
12345-- 08:40 09:30 Milan LIN until 30.10
-----6- 16:45 17:25 Milan MXP until 30.10
(this info is give without a 100% garanty, this comes straight from
the BRU timetable)
So at this days you should have the most chance to spot him.
Best regards: yannick :D
