Abnormalities in BRU-ANR-CRL-LGG-OST in 2016
Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2016
Passenger wrote:Yesterday's TB-303 (Jetairfly / TUI Belgium OO-JDL 787-8) BRU-PUJ Brussels-Punta Cana made a u-turn past London, and returned to Brussels.
The aircraft took off again for Punta Cana some 4 hours after arrival back in Brussels.
ATC closed 25R after their landing, quote, "... for an inspection due to an intervention..."
Established02 wrote:
Passenger wrote:On 5th October 2016, an Air Dolomiti ERJ-195 (BRU-MUC, LH-2293) departed EBBR BRU 07R without take off clearance, forcing an Aer Lingus A320 (EI-638, DUB-BRU) to go around on ATC's instructions.
L'Echo: Collision évitée de justesse entre deux avions dans le ciel bruxellois
http://www.lecho.be/entreprises/aviatio ... 1476295739
Update Aviation Herald: "...On Oct 20th 2016 Belgium's AIB reported that the occurrence was rated a serious incident and is being investigated..."
Shengenzone
Post by Shengenzone »
A friend of me was supposed to fly from Faro to Brussels on saturday with flight SN 3802. Unfortianetly the aircraft (A320) had a technical issue and they had to dissembark. They where bussed to the terminal. Where they waited till 20:00 hours. Then they went to a hotel and where promised a departure the next day. The next day they arrived in the morning at the airport and waited for their new flight SN 1802. They boarded at 18:30 (2 hours later than sheduled) Moved down the tarmac and once again the pilot turned around and they where taken to the terminal by bus and promised a departure at 22:00 hours. In the end they finally departed this morning...
Shengenzone wrote:A friend of me was supposed to fly from Faro to Brussels on saturday with flight SN 3802. Unfortianetly the aircraft (A320) had a technical issue and they had to dissembark. They where bussed to the terminal. Where they waited till 20:00 hours. Then they went to a hotel and where promised a departure the next day. The next day they arrived in the morning at the airport and waited for their new flight SN 1802. They boarded at 18:30 (2 hours later than sheduled) Moved down the tarmac and once again the pilot turned around and they where taken to the terminal by bus and promised a departure at 22:00 hours. In the end they finally departed this morning...
If these are the facts, this situation was really badly managed (or not managed at all!) by SN's operations.
tangolima
Post by tangolima »
The morning flight LCY ANR diverted to RTM due to the weather at ANR
United Airlines flight UA951 from Brussels to Washington (Boeing 777-200 reg. N795UA) is doing U-turn over Atlantic and diverting
Incident on landing in SXF of a Ryanair 738 from Brussels: http://avherald.com/h?article=4a028071&opt=0
Fri 04 Nov: Ryanair FR-2935 Brussels-Treviso (EI-FRZ) diverted to Venice after going into a holding for 25 minutes, west of Treviso.
EI-FRZ repositioned from VCE to TSF as FR-935 about 75 minutes after landing at VCE.
https://www.flightradar24.com/data/aircraft/ei-frz/
luchtzak FR-2935 4 nov 2016.png (710.93 KiB) Viewed 5530 times
05 Nov: Ryanair FR-2918 BCN-BRU Barcelona-Brussels returned to BCN, some 10 minutes after take off.
https://www.flightradar24.com/data/flig ... 18#b85c962
luchtzak FR-2918 5 nov 2016.png (553.15 KiB) Viewed 5479 times
Incident from 07th Nov: A Wizzair A320-200 performing flight W6-2927 from Ljubljana (Slovenia) to Brussels Charleroi (Belgium), was enroute at FL350 about 20nm south of Munich (Germany) when the crew decided to divert to Budapest (Hungary). A passenger reported the crew indicated they were diverting to Budapest due to a lightning strike received earlier.
Source - more info:
http://avherald.com/h?article=4a070a29&opt=0
Post by DIBO »
Two days in a row, disruptions in the ANR schedules:
* twice one of the two daily Chalair's Hamburg flights was cancelled
* TUI's Nador flight, yesterday operated out of BRU with B737
* today's BCN arrival diverted to BRU and the subsequent Murcia flight was operated with B737 out of BRU
TB-302 TUI Belgium MBJ-BRU Montego Bay-Brussels (767-300ER OO-JNL) diverted to DUB Dublin this morning:
https://www.flightradar24.com/data/aircraft/oo-jnl/
If data on Flightradar24 are correct, the 767 landed in DUB at 09h40 UTC and continued from DUB to BRU at 17h00 UTC (and positionned from BRU to AMS tonight).
luchtzak TB-302 9 nov 2016.png (469.52 KiB) Viewed 5026 times
BRUpilot
Post by BRUpilot »
The ANA flight of yesterday evening departed with almost 15 hours delay. Anybody knows the reason?
Did you check the arrival time from Tokyo?
BRUpilot
Post by BRUpilot »
convair wrote:Did you check the arrival time from Tokyo?
Yes, sir. And it arrived well on time. Even 30 minutes behoren scheduled landing time.
LO-8177 Tallinn-Brussels returned to Tallinn just after take off (ES-ACD Nordica CRJ-900ER). About 45 minutes later, the flight took off for BRU again, and landed there at 21h20 (ETA 19h50).
luchtzak LO-8177 24 11 2016.png (454.9 KiB) Viewed 4408 times
Foggy in CRL ?
2 wizzair landed in LGG
One of them made a go around when trying to land in CRL again
Acid-drop wrote:Foggy in CRL ?
And the repositiong from LGG to CRL is making circles right now:
https://www.flightradar24.com/WZZ2281/bb6a74c
Already in a holding above CRL for one hour now!
any idea what happened ?
