Aviation24.be uptime/downtime topic
Re: Aviation24.be uptime/downtime topic
Aviation24.be is currently invaded with a specific crawler, causing high load to the server. Pages are also loading slower than expected. Rest assured that we are putting all our effort in to reduce the server load and to optimize the website ASAP.
An out-of-control crawler called BLEXBOT opened over 800 sessions in the forums. We have now blocked a series of IP-addresses from our forums. In case you don't have access to the forums, please contact us.
Past hour, we are facing a high load issue on the server. The website is hard to reach. Keep you posted!
Lots of bot-sessions are opened in the forums, causing a high peak on the server. We are closely monitoring the situation.
Webpage was unavailable early this morning, was back again at +/- 9:20 utc
Only the forums?jan_olieslagers wrote: ↑26 Jan 2020, 10:31 Webpage was unavailable early this morning, was back again at +/- 9:20 utc
Sorry, I couldn't say; I only tried search.php?search_id=active_topics, the "active topics", my usual point of entry
Yesterday and today. Home page usually accessible but hitting "Active Forums" doesn't go through 8 times out of 10.luchtzak wrote: ↑26 Jan 2020, 14:15Only the forums?jan_olieslagers wrote: ↑26 Jan 2020, 10:31 Webpage was unavailable early this morning, was back again at +/- 9:20 utc
Quick Links > Active Topics.
5 other attempts in last 90 minutes, all OK.
Tech support message:
There were a number of suspicious requests from IP range 114.119.128.0/18 (Singapore) so we blocked this IP range at your firewall.
The past 12 hours, the website is seeing more visitors than usual. This morning (UTC +2) an error occurred in one of our databases, resulting in an error display when visiting the forums as a logged-in member. In the mean time, this error has been fixed.
On Sunday, the website experienced server issues. Technics started working on the issues, which have now been completely solved.
Last night, the server moved to a new location. A downtime of around three hours was noted.
Yesterday, a few articles of our main page resulted in a performance issue of our server.
It was difficult to use the backend of the main site and the forums.
IT started working on the problem.
We are continuing to monitor the situation.
Thanks for your patience.
Our IT-services are performing some updates on the server, intermittent interruptions of the website are possible. Thanks for your patience during the possible downtime.
The website is moving to a new server, downtime might be possible. There is a possibility that you have to republish your messages in the forums.
Yesterday, the move didn't go as expected. With a lot of downtime. Today, the IT department continued working on a move. DNS should now resolve towards the new server, unfortunately this is taking more time than expected.
We thank you for your patience during this move, which is key for an up-to-date and highly performant server.
