Temp in baggage hold
Konus
Post by Konus »
What is the average temperature in the baggage hold for commercial airlines on Airbus/Boeing aircraft ?
Re: Temp in bagage hold
Will depend much on altitude. Besides, why ask for an "average"? Explaining the question might help in getting useful answers.
Re: Temp in baggage hold
The temperature should never be either too warm or too cold, because live animals travel in the baggage hold.
Konus
Post by Konus »
jan_olieslagers wrote: 21 Sep 2019, 18:17 Will depend much on altitude. Besides, why ask for an "average"? Explaining the question might help in getting useful answers.
Someone I know will have to travel with a medical electronic device, much too large for carry-on luggage. The equipment may not go under 0°C.
Thanks for the info.
The cargo holds of a passenger aircraft are pressurized and its air temperature remains positive throughout the flight.
The ECS, Environmental Control System, provides the aircraft pressurization and air temperature as required through the different zones. Therefore the conditioned air is, after being circulated through the cabin, forced down to the holds before being partially recirculated (*) via the recirc fans and HEPA filters.
This air is routed down along the sidewalls of the hold as these are not as well insulated as the cabin walls and are directly exposed to the external air which is at very low, negative, temperatures at high altitudes.
So goods, or live animals, may be safely transported inside the cargo hold but should never been placed next to the fuselage skin.
On wide body aircraft, live animals and temp sensitive goods are usually placed in the "bulk hold" whose temperature may be set separately at a higher value than the FWD and AFT holds.
Therefore do mention this while checking in. The package will be specifically identified and a label applied.
IATA label for time and sensitive cargo :
IATA TTSC2.jpg (11.19 KiB) Viewed 13597 times
(*) for some reason, the air from toilets and galleys are not recirculated and discharged directly out.
Maybe also specify the aircraft in more detail. B777 allows certain temperature control, B737 not. But it is supposed to be positive all the time.
blonko
Post by blonko »
This air is steered down along the sidewalls of the hold as these are not also protected as the lodge dividers and are straightforwardly presented to the outside air which is at low, negative, temperatures at high elevations.
So merchandise, or live creatures, might be securely shipped inside the load hold yet ought to never been set close to the fuselage skin.
On wide body airplane, live creatures and temp delicate products are generally positioned in the "mass hold" whose temperature might be set independently at a higher incentive than the FWD and AFT holds.
Squawk 7500 .....
