2020 Liège Airport (LGG/EBLG) latest news
737MAX
Re: 2020 Liège Airport (LGG/EBLG) latest news
Post by 737MAX » 23 Mar 2020, 08:04
22 Mar 2020, 23:09
Acid-drop wrote:
22 Mar 2020, 22:32
Can anyone comment if Liège is overloaded these days ?
I see less and less qatar flights and some source* mention Basel is used instead of LGG and LUX.
I also see qatar flights from MST.
Is it that crowded ?
Where is the bottleneck ?
* https://skynews.ch/zivilluftfahrt/merkl ... roairport/
I think your answer is here: viewtopic.php?f=21&t=68294
Hmmm, have you ever been at LGG by night?
You can’t seriously think that’s the list of all the scheduled flights at LGG...
Post by Acid-drop » 23 Mar 2020, 08:06
Not that fast.
Some hours are crowded, some arent
LGG is busy, thats for sure but i would be nice to understand better. I suspect parking in cargo north is the bottleneck, when should the new one be ready ?
Post by flightlover » 23 Mar 2020, 10:25
737MAX wrote:
23 Mar 2020, 08:04
22 Mar 2020, 23:09
Acid-drop wrote:
22 Mar 2020, 22:32
The flights for TNT are most probably not booked as sheduled. Therefore this list might be correct indeed.
For BRU, for example, most flights handled by DHL are booked as chartered flights.
SR20
Post by SR20 » 23 Mar 2020, 11:06
Acid-drop wrote:
23 Mar 2020, 08:06
Not that fast.
Since early february 6 new stands have been open on the northern apron. There are now 16 stands available on the northern cargo apron.
Post by Acid-drop » 23 Mar 2020, 12:45
So where is the bottleneck ?
Why is qatar sending flights to maastricht and basel ?
Any pictures of the new parking spaces ?
737MAX
Post by 737MAX » 23 Mar 2020, 13:06
Acid-drop wrote:
23 Mar 2020, 12:45
The question is... where did you get this from? Why that question?
QTR is still flying to LGG, why would flights to MST & BSL imply there is a "bottleneck" in LGG???
737MAX
Post by 737MAX » 23 Mar 2020, 13:07
flightlover wrote:
23 Mar 2020, 10:25
I obviously meant; this is not the list of all the movements that will happen in LGG today/tonight...
BRU
Post by BRU » 23 Mar 2020, 13:47
737MAX wrote:
23 Mar 2020, 13:06
Acid-drop wrote:
23 Mar 2020, 12:45
LUX is an issue, so flights you see in BSL and MST are flights that were operated to LUX before. Nothing to do with LGG.
Post by Acid-drop » 23 Mar 2020, 14:55
So why isnt LGG taking those over ?
Something is failing there.
Im trying to understand
ostair
Post by ostair » 24 Mar 2020, 01:41
What is the problem with LUX?
BRU
Post by BRU » 24 Mar 2020, 23:26
LUX is facing Manpower issues, and priority Goes to cargolux. And also LGG is seeing Manpower with handling agents as the biggest bottleneck at this moment. Same at other airports. That is reason why some airlines like to put some flights at different airports rather than consolidating at a few or a single airport.
SR20
Post by SR20 » 25 Mar 2020, 10:56
Handlers point out that due to the high level of sickness absence during cargo handling at Liège Airport and Luxembourg Airport, airlines move flights to Schiphol and other airports in the region. In Luxembourg, priority is now being given to handling the cargo flights of the national cargo carrier Cargolux, a source reports
Qatar Airways Cargo has departed en masse from Liège and Luxembourg to Schiphol and also uses Maastricht Aachen Airport (MAA) and even the Flemish Ostend Airport. In addition, the Limburg airport now handles cargo flights of Ethiopian Airlines and charter flights with e-commerce goods, which would normally land at Liège Airport. Russian AirBridgeCargo, which also flies for Emirates SkyCargo, has also shifted part of its cargo flights to MAA and other airports.
https://www.nieuwsbladtransport.nl/luch ... dpr=accept
Post by Acid-drop » 25 Mar 2020, 11:51
I expected a failure but this is much bigger than I imagined :(
but to be fair, it's a dutch article with a dutch bias, it's not THAT bad. but there is a shift, that's for sure
ostair
Post by ostair » 25 Mar 2020, 23:56
Thanks for the info.
At the time of writing A7-BFR is heading for OST.
Airbus330lover
Post by Airbus330lover » 26 Mar 2020, 11:28
Quatar flights to BSL for medicine. Basel is a big pharma city.... Novartis, ... easier to go direct to pick-up the goods.
Post by Conti764 » 26 Mar 2020, 12:01
Why are those airlines shifting to AMS when you have BRU much closer? With disapearing passenger flights I can imagine BRU handlers still have some spare capacity, no?
Post by Atlantis » 26 Mar 2020, 20:40
Conti764 wrote:
26 Mar 2020, 12:01
Spare capacity yes, but you also need the people.
Post by Conti764 » 26 Mar 2020, 20:53
Atlantis wrote:
26 Mar 2020, 20:40
Conti764 wrote:
26 Mar 2020, 12:01
That's what I mean with capacity. I imagine workers from pax ops can be shifted to cargo ops, no? Or is offloadig a cargoplane so much different then offloading cargo from a passenger plane?
Just asking...
BRU
Post by BRU » 27 Mar 2020, 00:22
People is not the problem in BRU. But they are also getting already extra flights. And depending on the handling agents, the situation can be very different from airline to airline.
Also, a lot of airlines were forced out of AMS due to slot restrictions in recent years. And suddenly they get slots, night slots and 7th freedom traffic rights to operate from the airport.
And finally, due to operational limitations (night curfew and fines Brussels Region!, BRU is not the favourite airport to fly to.
SR20
Post by SR20 » 27 Mar 2020, 19:07
