AIRMARSHAL
Post by AIRMARSHAL » 09 Jun 2018, 23:38
perhaps Cityjets' CRJ-900 series
Post by convair » 10 Jun 2018, 15:02
Toronto SN551 flight today operated with OO-SFC, one of the "newwest" SN aircraft. Its first revenue flight for SN, btw.
CTBke
Post by CTBke » 10 Jun 2018, 15:45
convair wrote:
10 Jun 2018, 15:02
nice to see they put it into service straight away, note that the cabin is still ex Cathay Pacific
Citybird
The flying dream
CTBke
Post by CTBke » 10 Jun 2018, 15:46
AIRMARSHAL wrote:
09 Jun 2018, 23:38
aren't they 'exclusively' for SAS as they're in their uniform? only the reg tells you it's a cityjet plane (and the safety card)
Citybird
The flying dream
DannyVDB
Post by DannyVDB » 11 Jun 2018, 06:53
But LH has no spare aircraft; why would they give it some of them SN?
I think they will stick to the SSJ for the time being ... another solution will need more time.
Just my two cents
D
PS: BTW, I was on an CRJ900 yesterday and a lot less comfortable than the SSJ100 ...
Post by Boeing767copilot » 11 Jun 2018, 08:42
In the meantime Cityjet to expand its fleet by up to seven CRJ-900s as part of a US$100 million deal to further expand its wet leasing operation, says executive chairman Pat Byrne.
The aircraft will be leased to Cityjet by part-owner and leasing company, Falko. The aircraft are currently undergoing maintenance and C-checks.
Two of the CRJs will be used by Cityjet as part of its current operation with SAS.
The Dublin-based airline is in talks with other major European carriers about similar operations.
Darjeeling
Post by Darjeeling » 12 Jun 2018, 14:25
The interior of OO-SFC is far from being a hard punishment:
https://www.jetphotos.com/photo/7815191
Basically the regional products of Asian carriers is up the long-haul product standards of many European carriers. This one is much more attractive than what EW proposes on the A340s.
Now, I know it's not good for product consistency, but still better than some old interiors on (very) ageing birds like SFM, SFN...
CTBke
Post by CTBke » 12 Jun 2018, 14:59
Darjeeling wrote:
12 Jun 2018, 14:25
EW's long haul product are the Business seats from Lufthansa ...and for a low fare airline a lot better than what you get on TUI or Norwegian
Citybird
The flying dream
theeuropean
Post by theeuropean » 12 Jun 2018, 16:06
CityJet has had also many problems with SAS with many cancellations, it doesn’t seem it is just related to the Sukhoi Super Jets. Maybe it’s an organisational issue of the company. So SAS has no put on pressure on CityJet to up their game.
Here’s the article in Danish but behind a paywall:
https://www.check-in.dk/sas-maa-aflyse- ... lyvninger/
RTM
Post by RTM » 12 Jun 2018, 16:10
Darjeeling wrote:
12 Jun 2018, 14:25
Please explain…
The current interiors on the LH SN fleet are less than 6 years old… Probably younger than the still factory interiors of the latest additions...
Post by lumumba » 12 Jun 2018, 17:26
RTM wrote:
12 Jun 2018, 16:10
Darjeeling wrote:
12 Jun 2018, 14:25
Please explain…
I can not compare with the new one but in Y the interior of Singapore Airline (SFX) was cleaner than the Y in SN plane's....
I think that they changed the seats but not all the interior for example I was seated on 37A ( it was a 200)in my last flight and the carpet was loose on my feet it was dirty!
Normally they have to change every 5 years I tough like that?
I'm not sure the interior of SFX is older that 6 years!
Also the there is no humidity in the windows of SFX in the older SN plane's yes you can not look true the windows anymore....
RTM
Post by RTM » 13 Jun 2018, 07:29
lumumba wrote:
12 Jun 2018, 17:26
When SFX entered service, it was more or less ok with the old interior. And yes, it was old. But after a few months, it was a nightmare, no spare parts, no spare cushions and/or covers. At the end, before it got its SN interior, it was hiddious.
As for carpets, they are replaced regularly. But the abuse is immense. Impossible to keep clean.
There is no requirement other than operators choice to replace an interior. If maintained well, it can last forever. It just won't be competitive anymore. That's the clue.
As for condensation, could be. Lots of factors play a roll in that though… But I won't argue that with age the airco distribution system looses some of its efficiency in this particular aspect.
Darjeeling
Post by Darjeeling » 13 Jun 2018, 09:51
Fact is a 9 years old airplane will always (most likely) look better than a 25 years old one.
There is retrofit and retrofit. When SN says it retrofits a plane it's minimalist to say the least. The last years (2005-2006 / 2012-2013) it was only removing old seats for new ones, almost the same lavatories, the same side paneling, the same old luggage bins, same lighting system, same galleys, no attention for the windows states except when damages were detected... yes indeed sometimes floor carpets were replaced.
Hence the fresh feel you could have when SFX was introduced. Everyone knows how SQ use to maintain its airplanes.
Post by KriVa » 13 Jun 2018, 13:09
I have personally seen, and even done part of, a retrofit of an Airbus at Brussels Airlines. I can tell you that a lot more work goes into it than simply the same old stuff vacuum cleaned.
RTM
Post by RTM » 14 Jun 2018, 07:42
Darjeeling wrote:
13 Jun 2018, 09:51
I don't think you have a clue of the amount of work carried out, aside from the cost.
To point one thing out, carpets are replaced several times per year… The aisle carpets even several times more than that…. But the cabin interior is by far the most abused system on an aircraft. It does suffer a lot. Did you actually see that "pristine" SQ interior on SFX right before it went for its long awaited retrofit? Shocking! And that was just wear and tear of one season...
Darjeeling
Post by Darjeeling » 14 Jun 2018, 12:06
:arrow: I don't want to minimize the work carried out when a retrofit is completed at SN (SN mechanics are amongst the best when it comes to line maintenance), but it's a fact that their retrofits are not always up the details. Look at how Delta retrofits its 767 for example. Some even feature the Boeing Signature interior. Which means a REAL new cabin. Moreover retrofits were often carried out in Malta by Lufthansa Technik IIRC.
As for SFX, it was SN managers choice to have it flown without having spare parts / upholstery / IFE parts to maintain the interior properly. SFX arrived in a very good state for an 8 years old cabin, and once again it was SN's choice to fly it like that knowing that SQ was willing to sell spare parts for the cabin, IFE... (of course we leave here the "dat moet niks kosten" policy...). Many airlines phase in "new" second hand airplanes straight with a new cabin to avoid any inconsistency in the product... timing permitting of course. ;)
RTM
Post by RTM » 14 Jun 2018, 17:05
Lets leave it at that.
I read your reply, and can only conclude that your reasoing is based on assumptions. That is fine. But not all of them are accurate.
Also, if you want to compare delta to SN, feel free to do so. But stay reaistic, they are apples an pears. The fastest ways to go out of business, especially in aviation, is spendng foolishly, and/or not seizing opportunities when they arrise. Always keep the big picture in mind.
You are welcome to have the last word, but I am not one of those that is going to drag a discussion for pages.
Post by lumumba » 14 Jun 2018, 18:25
On thing is sure all the platic furniture is still from SQ even the toilets it's so funny and kitsch....
Ansett
Post by Ansett » 14 Jun 2018, 21:45
Sorry or the broken record, Poiu, imho for a number of years now, we have seen that LH isi treating SN as a second class airline in the LH Group.
lucas
Post by lucas » 20 Jun 2018, 13:38
OO-SFD is now arriving in Brussels, coming in from Frankfurt
