Aviation24.be software update topic
Give your feedback, make new suggestions to improve https://www.aviation24.be, is there anything else we can do for you?
Re: Aviation24.be software update topic
16 Feb 2019, 13:57
Something is wrong with the menu's on our main page, an item I will try to sort out. The forums are available via a link that I added on the main page.
A caching issue has caused the glitch, solved now.
While I was performing updates on the staging site, an error on the server occurred. Unfortunately, the error also occurred on the active website hence the site was down for approximately 53 mins, but is up again as of 22:10 (UTC +1).
Saturday update day: performed several updates on our news section. Everything is running like expected.
Between 23:25 and 23:50 (UTC +1), the main site was down for necessary maintenance. Thanks for your patience.
A few updates have been performed on the main site. Hence, the forums were not available for about 15 minutes (13 March around 23:30 UTC +1)
The past hour, I performed a few updates in the software. All is running as it should be.
27 Apr 2019, 02:06
Completed the rest of the updates.
Aviation24.be forum has been updated to phpBB version 3.2.7
Aviation24.be main site has been updated to Wordpress release 5.2
Aviation24.be main site has been updated to WordPress 5.2.1 Maintenance Release
A 2-minute interruption of Aviation24's main site due to important updates. All is running as expected.
Another round of updates on our main page, all went well without a single hick-up and that's a big joepie! 8-)
Forum software updated to phpBB version 3.2.8
Performed a series of updates. All running just fine ;-)
At 9:00 (UTC +1), Aviation24.be's main site was down between 5 and 10 minutes as important updates needed to be performed. Thanks for your patience.
The forum software has been updated to version 3.3.0, according to the authors a solid, secure and stable version.
You can expect some slight modifications in lay-out and user experience.
Read more here: https://www.phpbb.com/about/launch/
