Bralo20
Re: Ethiopian Airlines Boeing 737 MAX crashes between Addis Ababa and Nairobi
Post by Bralo20 »
According to the latest rumours EASA is thinking about following the British CAA and could be ready to issue a blanket ban for the 737 MAX in Europe. Later today a statement is expected.
If EASA is indeed ready to do so I think FAA might have to follow wetter they like it or not, more and more countries are issuing a ban (or airlines are grounding the planes voluntary) but if a major authority with power over a major area issues a statement and a ban that's something a little different. Guess we have to wait and see.
TUI group airlines follow suit, more news ASAP on the main site.
German airspace has been banned for Boeing 737 MAX by Minister for Traffic, Andreas Scheuer.
Turkish Airlines ground Boeing 737 MAX fleet.
Austrian airspace closed for Boeing 737 MAX.
TUI fly Belgium OO-TMA returning from Hurghada and OO-MAX from Sal, expected to land this evening.
Bralo20
Post by Bralo20 »
I guess Belgium will follow with the airspace closure for the MAX also when those 2 planes are back at BRU? Probably the reason why they didn't follow France, The Netherlands, etc...
On the other hand, they are going to strike anyway so they'll close parts of it this night regardless :D
No need to close the Belgian airspace for 737 MAX as The Netherlands, U.K., France and Germany all closed already.
This article, published on Aviation24.be in November 2018 is currently trending:
Boeing 737 MAX Automatic Stall-Prevention System (MCAS) not in flight crew operations manual (FCOM):
https://www.aviation24.be/manufacturers ... nual-fcom/
Re: Ethiopian Airlines Boeing 737 MAX crashes between Addis Ababa and Nairobi - impact on Boeing 737 MAX
Belgian Minister of Transport François Bellot just tweeted that the Boeing 737 MAX will also be disallowed in Belgian airspace.
Bralo20
Post by Bralo20 »
Breaking:
EASA has closed European airspace for the Boeing 737 MAX starting from 19h00.
Luke777
Post by Luke777 »
hundreds of predictions, so here s an other one: Within a few weeks the MAX up and flying again, as for cause: very bad coincidences, a set of circumstances and no direct proof of technical malfunctions, anyway Boeing took some serious precautionary measures and reviewed the complete MCAS system, case closed.
luchtzak wrote: 12 Mar 2019, 17:06 TUI fly Belgium OO-TMA returning from Hurghada and OO-MAX from Sal, expected to land this evening.
It looks like they won't be able to return to BRU if EU ban is effective from 19:00 UTC. It's a bit stupid (panic decision!), imho; they should allow planes to return to base.
(Btw, maybe a dedicated topic would be appropriate)
Luke777 wrote: 12 Mar 2019, 18:54 hundreds of predictions, so here s an other one: Within a few weeks the MAX up and flying again, as for cause: very bad coincidences, a set of circumstances and no direct proof of technical malfunctions, anyway Boeing took some serious precautionary measures and reviewed the complete MCAS system, case closed.
Not so sure. Too many dangers for the passengers. Do you keep all passengers seated with seatbelts on? How many g's does the thing create pitching down at 300kts? Does the g-load even allow pilot intervention? If the system fails, it should fail passive. Not active. The software update already mentions a reduced max input and elevator change rate (if I understand correctly). If it is the same cause as the Indonesian.
Btw, ferry flights for maintenance purpose can have special authorisation... I hope.
As an airline, the safety and security of our passengers and crew is always our first and key priority. With regard to the B737 Max 8, all three of our Max 8 aircraft are being grounded in compliance with the directive issued by Enac this evening.
As stated previously, all aircraft that we operate are always in full compliance with the regulators' instructions and manufacturer’s operating procedures. Air Italy will continue to be in constant dialogue with the authorities and Boeing with regard to our B737 Max 8 aircraft and will follow all directives to continue to ensure the maximum level of safety and security for our passengers and crew.
With respect to our ongoing operations, Air Italy will assist re-protect all passengers. We kindly ask passengers to check our website and social media channels for further travel updates or contact: Call Center +39 0789 52609 - option 2 o whatsapp +39 3470767469.
Both OO-TMA and OO-MAX are taking stranger routings. OO-TMA seems to divert to Venice. OO-MAX is descending above Spain. OO-TMY ferried from Ostend to Brussels.
I thought they would be able to continue to Belgium as already airborne before the decision.
