Brussels Airlines in 2018
Re: Brussels Airlines in 2018
Post by Desert Rat » 29 Dec 2018, 21:04
Poiu wrote:
29 Dec 2018, 00:49
29 Dec 2018, 00:03
There was also an IT issue for the left engine!
Contaminated fuel is know as a cause of engine electronic malfunctions.
Can you explain a bit more?
Thanks
Post by Poiu » 30 Dec 2018, 11:32
Desert Rat wrote:
29 Dec 2018, 21:04
Poiu wrote:
29 Dec 2018, 00:49
29 Dec 2018, 00:03
Thanks
One of the most documented cases is a CX A330 with P&W engines who had electronic problems on both engines after tanking contaminated fuel.
https://www.cad.gov.hk/reports/2%20Fina ... pliant.pdf
Chances of having two, unrelated engine problems on the same flight are as slim as winning the lottery 5 times in a row.
Post by sn26567 » 30 Dec 2018, 16:45
brussels airlines accelerates last SuperJet service to Jan 2019
brussels airlines in mid-December 2018 modified operation for its leased SuperJet SSJ100 aircraft from CityJet, which saw the last flight accelerated to the first week of January 2019, instead of late-March 2019.
Planned last Sukhoi SuperJet SSJ100 operation as follow.
Brussels – Basel/Mulhouse last flight 04JAN19
Brussels – Birmingham last flight 31DEC18
Brussels – Billund Overall last flight on 07JAN19, departing Billund
Brussels – Bologna last flight 06JAN19
Brussels – Krakow last flight 06JAN19
Brussels – Milan Malpensa last flight 04JAN19
https://www.aviation24.be/airlines/luft ... uary-2019/
Source: Jim Liu in Routesonline
Bel33
Post by Bel33 » 30 Dec 2018, 17:39
CRJ 1000 is not the best aircraft to replace the SSJ. I hope it's only for a short period while waiting for Embraer 90 or...Airbus A220? Let us dream...
Post by sn26567 » 30 Dec 2018, 17:56
I fear that the CRJ is there to stay quite a while. The SSJ contract was for two years...
cathay belgium
Post by cathay belgium » 30 Dec 2018, 18:15
Checked the booking system..
BHX by CRK and later on background to A319...
BLL by CR9....
No painted CRJ 's soon...
CXB
New types planned for 2019 : A223
New types flown : AN24,AW139,B737MAX8,B763nonER,EMB110 Bandeirante, Shorts360,Autogire MTOsport2010
Post by RoMax » 30 Dec 2018, 22:13
Darjeeling wrote:
29 Dec 2018, 11:55
...well let's rather say that this is what the internal communication dept of SN says of it. ;)
I've rarely seen an airline choosing a seat that isn't yet certified but that still is for sale on the market. :?
It actually happens all the time. Each time something is changed to the basic off the shelf model, seats require new certification (can be 'minor' if it's just a special new fabric used or something or it can be extensive if something more structural is customized). And plenty of airlines order customized models of existing models (also SN). And in addition the cabin as a whole also needs to be certified again depending on what has been changed.
Btw SFD is in the proces of its cabin retrofit (it was partly stripped of its cabin anyway as a donor for SFC and SFB), that's not because LH still has to decide on which seats to put in there...
