General Aviation incidents & accidents - worldwide
Post by Passenger » 28 Jul 2018, 11:36
27th July 2018: four fatalities near Anniviers (Suisse) - crash of a Robin:
https://www.arcinfo.ch/articles/suisse/ ... idi-773582
Re: General Aviation incidents & accidents - worldwide
Post by Passenger » 30 Jul 2018, 13:57
29th July 2018: 1 fatality, 7 injured: King Air 90 reg PP-SZN crash at Sao Paolo, Brazil. The aircraft made a third low-pass for visual landing gear inspection:
https://aviation-safety.net/wikibase/wiki.php?id=213808
Post by Passenger » 04 Aug 2018, 11:19
18 fatalities in Siberia: crash of RA-25640, a Mil Mi-8AMT helicopter, operating for an oil company. Apparently collision with the load from another helicopter.
https://aviation-safety.net/wikibase/wiki.php?id=214024
https://sputniknews.com/russia/20161022 ... er-crash/
RIP.
Post by sn26567 » 04 Aug 2018, 18:02
Several die after small plane crashes in Swiss forest
Several people died after a small plane crashed in a Swiss forest on Saturday morning, causing a forest fire that completely destroyed the plane, police said.
http://www.euronews.com/2018/08/04/seve ... iss-forest
Vic Diesel
Post by Vic Diesel » 05 Aug 2018, 10:36
04 Aug 2018, 18:02
The aircraft affected in the crash was HB-HOT of Swiss operator Ju Air, one of the few remaining Ju-52 worldwide.
http://avherald.com/h?article=4bbf2069&opt=0
Viktor
(Budapest-born, Vienna-raised, working in Brussels)
Post by luchtzak » 05 Aug 2018, 10:39
Vic Diesel wrote:
05 Aug 2018, 10:36
04 Aug 2018, 18:02
Two incidents have occured on yesterday, a small aircraft and the Ju Air.
https://www.aviation24.be/airlines/ju-a ... found-yet/
Post by Passenger » 05 Aug 2018, 13:00
04 Aug 2018, 18:02
It was a Socata TB-10.
Post by luchtzak » 05 Aug 2018, 15:00
No survivors in the Ju-Air plane crash, this is sad ...
https://www.aviation24.be/airlines/ju-a ... the-crash/
Post by Passenger » 05 Aug 2018, 15:19
Regarding fatal accidents reported on Aviation-Safety.net, 2018 is above the 5-year average at this moment.
Post by jan_olieslagers » 05 Aug 2018, 15:59
..and well above indeed. Sad enough. And that is even without counting the (257?) victims of the Algerian Il-76 crash, that was military, so it was left outside the statistic.
Post by Passenger » 06 Aug 2018, 00:30
Not much comment to add, except for a RIP:
https://www.dailynews.com/2018/08/05/pl ... rking-lot/
Post by Passenger » 06 Aug 2018, 23:34
4 Polish tourists dead, 1 missing:
a DHC-2 de Havilland Beaver crash in Alaska:
http://www.ktva.com/story/38817205/dena ... ume-monday
Post by Passenger » 09 Aug 2018, 17:41
PH-CJX Beech Baron G58 during landing at Münster-Osnabrück airport EDDG:
https://aviation-safety.net/wikibase/wiki.php?id=214261
It's this one - and the article reveals most probably the name of one of the two victims:
https://www.aironline.nl/weblog/2018/07 ... d-airport/
Post by Passenger » 12 Aug 2018, 14:09
8 fatalities in Indonesia:
"...A PAC 750XL of Dimonim Air is reported missing on a flight between Tanahmerah Airport and Oksibil Airport, Papua, Indonesia. The flight should have a duration of 42 minutes but failed to arrive at Oksibil.
Search operations are being conducted. Some people in a village reported they heard loud sounds and an explosion. There were two pilots and seven passengers aboard. The wreckage of the plane was located near Oksibil Airport. Eight occupants died in the crash, a boy was the only survivor. The aircraft made the first contact with Oksibil Tower at 05.11 UTC, then the ATC communicated to them the weather report . At 05.17 UTC PK-HVQ reported an overhead position at 7,000 feet. After the overhead position, communication between Oksibil Tower officers and the plane was immediately cut off. Oksibil Tower officials also were unable to communicate outside the Oksibil area using cellphones due to signal conditions..."
Source:
https://aviation-safety.net/wikibase/wiki.php?id=214373
Manufacturer:
http://www.aerospace.co.nz/aircraft/p-7 ... escription
Post by sn26567 » 13 Aug 2018, 15:32
A 1944-vintage DH89 Dragon Rapide registered N683DH (still wearing former UK registration G-AHXW) crashed at the Abbotsford Air Show in British Columbia yesterday (SE of Vancouver), injuring the pilot & 4 passengers.
https://t.co/inegOzluF1
Post by sn26567 » 16 Aug 2018, 17:10
05 Aug 2018, 15:00
It was reported elsewhere on this site that Ju-Air wanted to restart flying with its remaining Ju-52 aircraft after 16 August.
https://www.aviation24.be/manufacturers ... in-august/
On Aug 16th 2018, BAZL (the Swiss CAA) reported that the investigation so far has not revealed any clues to a technical cause of the crash of Aug 4th 2018. Nonetheless, the BAZL demands that a number of precautionary measures are being implemented by Ju-Air prior to resuming flying operations on Aug 17th: all aircraft must carry a recording GPS receiver to permit assessment of flight routes, the aircraft must observe an increased minimum safety height above legal requirements and the passengers must remain seated with their seat belts fastened throughout the flight and are no longer permitted to move freely within the aircraft (including cockpit visits). Ju-Air have already indicated they are going to comply with the demand. The investigation is ongoing and could take several weeks to months until first preliminary results. Should during the investigation new information of a technical problem be found, the BAZL will again assess the situation and may introduce new measures up to grounding the aircraft.
(source
: The Aviation Herald)
Post by Passenger » 25 Mar 2019, 11:53
One fatality in a suicide crash at FBMA Matsieng Air Strip in Botswana (Southern Africa), aircraft involded A2-MBM = a King Air B200:
SA press:
https://citizen.co.za/news/news-africa/ ... d-friends/
https://www.news24.com/Africa/News/watc ... e-20190324
Avcom South Africa:
https://avcom.co.za/phpBB3/viewtopic.php?f=9&t=217231
Post by Passenger » 08 Apr 2019, 14:36
Rescue mission is ongoing now near Rotterdam Airport (NL) for this one - two occupants, apparently not too badly injured:
