brusselsairlinesfan
Post by brusselsairlinesfan »
Yuqu12 wrote: 04 May 2017, 09:42 Some A319 and an A20.
A319's and 1 A320? Is that confirmed?
brusselsairlinesfan wrote: 04 May 2017, 10:12
The Avro's will fly the summer season till the end I guess and an A320 from EI will arrive during summer if I'm correct ! Then 2 A320 fron HQ will arrive too...
Yuqu12
Post by Yuqu12 »
Correct me if I'm wrong, but I thought that the SSX and SSO can also be seen as replacement of the RJ100, so that would mean that the 12 RJ100 are replaced by 3 SSJ100, the SSX and SSO, SNI and then the 2 OO-TC?
RTM
Post by RTM »
Yuqu12 wrote: 04 May 2017, 10:54 Correct me if I'm wrong, but I thought that the SSX and SSO can also be seen as replacement of the RJ100, so that would mean that the 12 RJ100 are replaced by 3 SSJ100, the SSX and SSO, SNI and then the 2 OO-TC?
Well... since the replacement of the 12 remaining Avro's already started last year, I think it is only fair to include SSL, SSJ, SSS, SNE and SNH in the equation...
DWB will stop ops in a few weeks time, leaving DWC, DWD and DWE to continue through the summer.
SNI will start ops mid june, but also SSD will be fased out at the end of the year. TCH and TCV will probably start transfer at the end of the year. Don't know when start ops with SN will be. But my guess is early next year.
Anyway, 12 Avro's and 1 A319 out, 5 A319, 5 A320 and 3 SSJ in.
crew1990
Post by crew1990 »
RTM wrote: 04 May 2017, 15:47
The 2 A320 coming from TCW are not replacement aircraft they come in the same time than all the winter operation of Thomas Cook
RTM
Post by RTM »
crew1990 wrote: 04 May 2017, 18:02
I actually know that, they are expansion to take over the TC ops. However, just looking at the numbers, I see 13 out and 13 in. But I was just answering to Yuqu12 who counted 12 out 8 in.
DeltaWiskey
Post by DeltaWiskey »
The RJ100's are, all but one, replaced by either an SSJ or A32F. There normally is/was one spare aircraft for each family, but it was decided to not replace the "spare" RJ100. As from this summer, there will be just one spare aircraft for the whole single aisle fleet. (During the winter it's less of an issue.)
DeltaWiskey
A small comparison:
Fleet Spring 2007 (start of Brussels Airlines, post-Virgin merger):
6 BAe146-200
14 RJ85
12 RJ100
5 737-300
5 737-400
3 A319
4* A330
total single aisle: 45
total widebody: 4
total number of seats: 5798
Expected** fleet November 2017 (after phase-out of Avro, incl. TCAB):
22 A319
12 A320
4 A330-200
6 A330-300
3 SSJ100 (wet lease)
2 Q400 (wet lease)
total single aisle: 39 (34 excl. wet lease)
total widebody: 10
total number of seats: 8544
*4th joined in June 2007
**Airbus family numbers are more or less firm, wet leases are still likely to change
RTM
Post by RTM »
The ERJ is discontinued?
DeltaWiskey
Good question, I don't know exactly what will happen with the ERJ. The ERJ and DH8 contracts are up for renewal and will likely be replaced by just one type. That's why I made a note that the wet leases are still likely to change, the 5 frames are a minimum, imo.
DeltaWiskey wrote: 04 May 2017, 19:38 The RJ100's are, all but one, replaced by either an SSJ or A32F. There normally is/was one spare aircraft for each family, but it was decided to not replace the "spare" RJ100. As from this summer, there will be just one spare aircraft for the whole single aisle fleet. (During the winter it's less of an issue.)
I guess Cityjet will be responsible for the spare SSJ100, if one of the three current ones is AOG. It actually already happened once when EI-FWA was sent for an SN flight.
In the same way, Flybe is regularly sending a Q400 in its own colours to replace one of the two painted in SN livery.
DeltaWiskey
sn26567 wrote: 04 May 2017, 21:06 I guess Cityjet will be responsible for the spare SSJ100, if one of the three current ones is AOG. It actually already happened once when EI-FWA was sent for an SN flight.
They're always sent for an SN flight ;)
I guess you mean as a replacement for an RJ100 flight?
sn26567 wrote: 04 May 2017, 21:06 In the same way, Flybe is regularly sending a Q400 in its own colours to replace one of the two painted in SN livery.
If one of the contract aircraft are sent in for maintenance, its logical that it is replaced by another aircraft by the lessor (likely not in SN livery). But that's not what I meant as "spare" aircraft. I meant a standby aircraft, one that is ready to be dispatched in case of AOG. I think the lessors are only required to supply one if one it concerns a contract aircraft, not for an RJ100 or A32F AOG.
RTM wrote: 04 May 2017, 20:49 The ERJ is discontinued?
DeltaWiskey wrote: 04 May 2017, 20:58 Good question, I don't know exactly what will happen with the ERJ. The ERJ and DH8 contracts are up for renewal and will likely be replaced by just one type. That's why I made a note that the wet leases are still likely to change, the 5 frames are a minimum, imo.
The ERJs fly to quite a number of SN destinations, like Basle, Bremen, Nantes, Nurenberg, Strasburg, Torino, and of course Bristol. Usually 2 aircraft seem to be dedicated to SN, but very often there are 3 of them flying (for SN) at the same time. Their replacement doesn't seem imminent.
The 5 frames mentioned above by DeltaWiskey will not be enough to replace all wet-leased if they include the SSJ.
brusselsairlinesfan
DeltaWiskey wrote: 04 May 2017, 20:42 A small comparison:
6 BAe146-200
14 RJ85
12 RJ100
5 737-300
5 737-400
3 A319
4* A330
total widebody: 4
22 A319
12 A320
4 A330-200
6 A330-300
2 Q400 (wet lease)
total widebody: 10
What a nice move indeed!
aérienne
Post by aérienne »
Sukhoi RRJ95 B 95117 EI-FWE CityJet delivery 08 May17 VCE-BRU, Brussels Airlines cs ex I-PDVX
aérienne wrote: 06 May 2017, 17:06 Sukhoi RRJ95 B 95117 EI-FWE CityJet delivery 05 May17 VCE-BRU, Brussels Airlines cs ex I-PDVX
Thanks for the update.
aérienne
Post by aérienne »
you're welcome:-) Regards
lenain258
Post by lenain258 »
lenain258 wrote: 07 May 2017, 16:33 https://www.flickr.com/photos/shanair/34378672921/
First picture of OO-SNI ;-)
And some extra information: https://www.aviation24.be/airlines/lufthan ... rbus-a320/
lenain258
Post by lenain258 »
EI-FWE is on the way to Brussels
