OO-JDL in holding pattern near OST
Bralo20
Post by Bralo20 »
It seems to be dumping/burning off fuel?
https://www.flightradar24.com/JAF705/9938fc2
So I assume the plane has a technical problem.
EDIT: It just turned back to BRU
Flyuli
Re: OO-JDL in holding pattern near OST
Post by Flyuli »
on ground
Post by quixoticguide »
yes, there was a technical problem according TB.
according TB
What is TB ?
Tui Belgium?
cathay belgium
Post by cathay belgium »
TB = official IATA code for Jetairfly, former and official Tui Airlines Belgium.
( but you will mostly see JAF ( it's ICAO coding )... but official it's TB .... )
at least it was, but now it's all merged ... what would it become ?
CXB
New types flown 2022.. A339
cathay belgium wrote:TB = official IATA code for Jetairfly, former and official Tui Airlines Belgium.
CXB
You will no longer see JAF. I spoke with the spokespersons of JAF today (Hans and Florence, plus de new one Pieter-Jan), and Jetairfly was asked to use the two-letter code, hence they will use TB from now on.
I'm all mixed up here now.
IIRC, we have :
1) the IATA Airline Code which is a 2-character designator, e.g. SN / BA / TB / AF / LH
and
2) the ICAO Airliner Designator which is a 3-character code, e.g. BEL / BAW / JAF / AFR / DLH
You may then add their respective R/T code, e.g. BeeLine, SpeedBird, Beauty, Air Fancy, OttoPilot…
Do the changes at JetairFly affect their codes as well? What will they be?
Thanks.
Homo Aeroportus wrote:I'm all mixed up here now.
IIRC, we have :
and
Thanks.
I understand your confusion. But I see it like this: the ICAO codes are used by/for professionals, the IATA codes by/for the public at large.
On the screens announcing flights at Brussels Airport, two-letter codes are used for most airlines (with of course a few exceptions: EZY, EZS, JAF, ...). Brussels Airport has thus asked JAF (and maybe also the others) to revert to their 2-letter code i.e. TB, for uniformity. As simple as that ;)
Bralo20 wrote:It seems to be dumping/burning off fuel?
Gear problem:
http://avherald.com/h?article=497afea4&opt=0
OO-JDL is back in the air and on its way to Cancun at FL340.
According to their spokesperson it was a flap problem:
http://www.standaard.be/cnt/dmf20160501_02268947 (in Dutch)
12 hours delay: 600€ x 300 pax = an expensive problem !
LJ
Post by LJ »
sn26567 wrote:OO-JDL is back in the air and on its way to Cancun at FL340.
Are you sure? AFAIK Tui leased the Privilege style B777 for this flight. Or did Tui operate 2 flights to CUN yesterday?
Then FlightRadar24 made a mistake by showing OO-JDL when I posted my message...
sn26567 wrote:12 hours delay: 600€ x 300 pax = an expensive problem !
Not exactly. Actually, I would go for "no 600 € compensation needed", only assistance (meals, drinks, hotels). There is jurisprudence from the European Court of Justice indeed in which a technical issue was refused as an extraordinary circumstance: passengers from an Alitalia flight (just google "Wallentin-Hermann"). However, the technical problem for their flight was an engine problem that was discovered the night before. The same court verdict also states that the initial judge may accept or refuse a technical issue as an acceptable extraordinary circumstance.
At this moment, there is an unofficial draft list of extraordinary circumstances, agreed upon in April 2013 by all National Enforcement Bodies of the European Union:
http://ec.europa.eu/transport/themes/pa ... s-list.pdf
Me thinks that OO-JDL's technical problem from yesterday (gear? flaps?) falls under accepted extraordinary circimstance n° 21 from the list = no indemnity to be paid: "...Unexpected flight safety shortcomings: Any technical issues which cause the pilot to carry out an aircraft turnaround or diversion..."
If passengers go to court, I'm quite sure Jetairfly will refer to this draft document to get the compensation waived.
Also, 261/2004 is being reviewed now. In the proposal of the new text (thus not valid at this moment), inflight incidents will probably also be excluded for the €€€ compensation: "Non-exhaustive list of circumstances considered as extraordinary circumstances for the purposes of this Regulation... The following circumstances shall be considered as extraordinary: ...technical problems which are not inherent in the normal operation of the aircraft, such as the identification of a defect during the flight operation concerned and which prevents the normal continuation of the operation; or a hidden manufacturing defect revealed by the manufacturer or a competent authority and which impinges on flight safety..."
(edited: review 261/2004 cleared with additional remark)
airrat
Post by airrat »
Privilege Style operated TB705. 706 is coming back with a day's delay since the company didn't have time to position a relief crew in CUN obviously.
Welcome to Luchtzak, airrat.
