Aviation24.be software update topic
Give your feedback, make new suggestions to improve https://www.aviation24.be, is there anything else we can do for you?
Re: The www.luchtzak.be update and downtime topic
we are currently redirecting to the new server, this procedure might take up to 48 hours but in general this is not that long.
It all depend the TTL of the dns entry, you may be able to tweak that settings before the migration.
I'm on the new one already, TTL seems to be 4h.
But there is another prob, we are redirected to http://31.193.177.82/~luchtzak/
the cookie for authentication will fail
Thanks for the information, Bottie and myself changed some settings and if all goes well in max 4 hours www.luchtzak.be will be available on the new server ;-)
www.luchtzak.com is already working!
I am now able to browse on the url again: www.luchtzak.be and not the IP adress (from France)
but apparently in Belgium this is still not the case, please be patient ;-)
Charlie Roy
Post by Charlie Roy »
Tapatalk works again :-)
Bottie
Post by Bottie »
Charlie Roy wrote:Tapatalk works again :-)
Everything should start to work fine again, if not, just mention it here in this topic.
Sam V
Post by Sam V »
luchtzak.be does not work (the adress without www.) when it did before
Bottie
Post by Bottie »
Sam V wrote:luchtzak.be does not work (the adress without www.) when it did before
Will be taken care off shortly
Tapatalk plugin has been updated, please confirm tapatalk is working fine!
tapatalk works fine!
www.luchtzak.be has been down for the past 15 minutes, the phpBB-forums are now up-to-date version 3.0.11 ==> https://www.phpbb.com/community/viewtop ... &t=2161321
A new version of the tapatalk plugin has been installed, as I don't have a smartphone I need somebody to check if all is working :idea:
luchtzak wrote:A new version of the tapatalk plugin has been installed, as I don't have a smartphone I need somebody to check if all is working :idea:
It works!
Bottie
Post by Bottie »
Due to some maintenance and updates (serverhard- and software), there are some downtimes today.
I hope these won't take too long :)
Thanks for understanding.
Bottie
Post by Bottie »
A hardware-upgrade will be performed on June 12th, around 6am. If all, and I don't expect any trouble, goes well, there will a downtime of about 5 minutes.
Thanks for understanding :)
Bottie
Post by Bottie »
Serverupgrade is finished. After the anounced RAM-upgrade I decided to do last-minute Hard Drive upgrade.
Server is good to go for another few years (I hope)
Bottie wrote:Serverupgrade is finished. After the anounced RAM-upgrade I decided to do last-minute Hard Drive upgrade.
:thumbup:
Bottie
Post by Bottie »
As some of you probably have noticed, luchtzak.be was hard to reach the last hours.
Due to a DDOS-attack on the server, I had to shut down some services untill all was over. On some moments, serverload was over 500 where 4.0 is actually 100%.
Let's hope adjustments I've made help and the attacks are over.
B
Treeper
Post by Treeper »
any idea who the criminal/s is/are? or where it came from?
Bottie
Post by Bottie »
Treeper wrote:any idea who the criminal/s is/are? or where it came from?
IP-ranges from China, Canada, Taiwan and Jemen ... but that means nothing, they can be 'spoofed'
