Kalitta 747-400 Dumping fuel
BigJets
Post by BigJets » 29 Mar 2019, 22:03
Kalitta 747-400 N740CK is dumping fuel at this moment. I heard multiple successive explosions as the aircraft past overhead.
BigJets
Re: Kalitta 747-400 Dumping fuel
Post by BigJets » 29 Mar 2019, 22:08
the aircraft is holding (fuel dumping) in front of the Belgian coast over the north sea
Treeper
Post by Treeper » 29 Mar 2019, 22:10
Heard it as well
Post by sn26567 » 29 Mar 2019, 22:12
BigJets wrote:
29 Mar 2019, 22:03
And where is "overhead" ?
BigJets
Post by BigJets » 29 Mar 2019, 22:19
Meise, Merchtem, Opwijk as it was climbing out. The engine was shut down around Opwijk when the explosions stopped. It shows similarities to a birdstrike however the aircraft was already quite high, although not impossible for it to still be a birdstrike it might indicate that something else may be the cause.
Post by luchtzak » 29 Mar 2019, 22:29
BigJets wrote:
29 Mar 2019, 22:19
Not higher than 7,000 feet, according to flightradar24
Treeper
Post by Treeper » 29 Mar 2019, 22:35
Seems to be returning to BRU.
Post by luchtzak » 29 Mar 2019, 22:39
BigJets
Post by BigJets » 29 Mar 2019, 22:41
Luchtzak, you're right, the Kalitta levelled at 7,000 feet. What I mean is that only about 10% of all birdstrikes are above 3,500 feet altitude and the explosions occurred at around 5 to 6,000 feet.
The aircraft is now on it's way to Brussels
Post by KriVa » 29 Mar 2019, 22:50
LGG seems more likely.
Post by luchtzak » 29 Mar 2019, 22:52
Still flying at 7,000 feet but passed Brussels Airport
Treeper
Post by Treeper » 29 Mar 2019, 23:02
Still at 7000, way past LGG now. Perhaps CGN?
Post by lumumba » 29 Mar 2019, 23:02
He is going to Leipzig....!?
Post by luchtzak » 29 Mar 2019, 23:05
Leipzig - Leipzig/Halle Airport
Frankfurt - Frankfurt–Hahn Airport
Ramstein - Ramstein Air Base
SR20
Post by SR20 » 29 Mar 2019, 23:09
29 Mar 2019, 23:05
I bet on LEJ 😉
BigJets
Post by BigJets » 29 Mar 2019, 23:11
Break time for the crew, autopilot - engaged :)
Treeper
Post by Treeper » 29 Mar 2019, 23:14
Isn’t it common to declare emergency after a compressor stall? But to go and dump fuel over the North Sea, and then going 2000km or so to LEJ at 7000ft... seems a bit excessive when you’re passing all sorts of alternates, no?
Post by luchtzak » 29 Mar 2019, 23:41
Treeper wrote:
29 Mar 2019, 23:14
3 engines still running, and perhaps maintenance bay in Leipzig ?
Post by lumumba » 29 Mar 2019, 23:50
29 Mar 2019, 23:41
Treeper wrote:
29 Mar 2019, 23:14
I think I just easy for the Cargo to be overloaded to another plane going to the USA.
Post by luchtzak » 29 Mar 2019, 23:58
Safely landed at Leipzig Airport.
