Anomalies in BRU-ANR-CRL-LGG-OST in 2019
Re: Anomalies in BRU-ANR-CRL-LGG-OST in 2019
Tuifly's OO-JEB Tangier->Antwerp diverted to BRU due to fog @ANR. Subsequent flight of OO-JEB to Palma departed from BRU with 1 hour delay, so all in all the impact for the passengers was rather limited.
Konus
Post by Konus »
DIBO wrote:
20 Oct 2019, 13:29
Exactly at the time OO-JEB had to land at ANR, OO-JEM departed without any problem from ANR to ALC. I live in crow flight not even 5 km from the aerodrome but did not see any fog at all.
Strange :o
Smoke in the cockpit for Monday's TB3141 CRL-SSH Charleroi-Sharm el Sheikh, operated by SmartLynx A320-200 ES-SAT:
passenger report:
https://www.aviation24.be/airlines/tui- ... andidates/
AvHerald.com:
http://avherald.com/h?article=4ce4817e&opt=0
Aircraft involved:
https://www.flightradar24.com/data/aircraft/es-sat
Konus wrote:
21 Oct 2019, 08:38
Strange :o
:roll: :lol:
It is clear you don’t have a clue about the definition of take off and landing minima! No problem at all and it’s absolutely fine to ask questions about it, but please refrain from making nonsense statements.
Norwegian D82899 CPH - LGW operated by EIGBB diverted this morning to BRU.
ZavCity
Post by ZavCity »
Why BRU? Is not on the direct route between the 2 cities..
gtz
paul
ZavCity wrote:
02 Nov 2019, 12:05
gtz
paul
Because it was the most suitable airport in the opinion of the pilot in command.
All SN long/haul are scheduled to arrive on time at destination today!
convair wrote:
03 Nov 2019, 12:48
You might indeed consider this as an anomaly :roll: :lol:
03 Nov 2019, 14:54
convair wrote:
03 Nov 2019, 12:48
Luckily we have Air Belgium who stepped in.
After the breakdown of OO-ABB on 28th October, the World Tour 2019 from French tour organizer Safarans du Monde was grounded for 4 days at Lima. Backup aircraft CS-TQP now continues the tour with Lima-Mataveri (Easter Island).
viewtopic.php?f=7&t=65198&start=280#p388671
lucas
Post by lucas »
A 747F operated by Air Atlanta Icelandic for Astral Aviation is returning to Liège. It dumped fuel above the North Sea. The dumping took about half an hour.
https://www.flightradar24.com/ACP2612/22bf8325
lucas wrote:
06 Nov 2019, 18:46
Destination was probably LOS Lagos:
https://www.flightradar24.com/data/flights/8v2612/
Next weekend (09-11 Nov), some trains to Brussels Airport will not operate:
NL:
https://www.belgiantrain.be/nl/news/wor ... we-airport
FR:
https://www.belgiantrain.be/fr/news/wor ... we-airport
Jamming tests planned :
A3794/19 NOTAMN
Q) EBBU/QGWXX/IV/NBO/E /000/050/5110N00423E001
A) EBBU B) 1911130800 C) 1911141800
D) DAILY 0800-1800
E) GNSS SIGNAL DISRUPTION POSSIBLE UP TO 5000FT AMSL 511026N0042315E
RADIUS 01NM DUR TO REMOTELY PILOTED ACFT SYSTEM (RPAS) JAMMING TESTS
CREATED: 08 Nov 2019 13:22:00
SOURCE: EUECYIYN
A3793/19 NOTAMN
Q) EBBU/QACLP/IV/NBO/AE/000/025/5111N00428E015
A) EBAW B) 1911130800 C) 1911141800
D) DAILY 0800-1800
E) ANT CTR REMOTELY PILOTED ACFT SYSTEM (RPAS) FLT PROHIBITED DUE TO
RPAS JAMMING TESTS.
CREATED: 08 Nov 2019 13:14:00
SOURCE: EUECYIYN
A3795/19 NOTAMN
Q) EBBU/QPIAU/I /NBO/A /000/999/5111N00428E005
E) IAP RNP RWY 11 NOT AVBL DUE TO RPAS JAMMING TESTS
CREATED: 08 Nov 2019 13:27:00
SOURCE: EUECYIYN
Why you want to cause GNSS signal disruption for testing purposes within 5 km of a regional airport and right below 2 of the most used SID's (Nicky & Gilom) is beyond me. Not that the onboard navigation equipment hasn't any alternative means when GNSS signals fail (enough DME's in the area), but just for the precautionary principle....
And no RNP's on RWY11, let's hope it isn't bad weather with easterly winds on those days...
And RPAS jamming tests in a populated city area...will they use airborne RPAS tests?? (I presume so). What if an RPAS goes haywire??
And next to the A12 highway, with all that traffic using GPS navigation software. I know it's not that big a deal, if you drive through a tunnel, you also loose also signal.
And did they inform all surveyors that might be active in the area, nowadays they use high precision GNSS signals, to do their surveyor work down to the centimeter, so to speak.
If they move just 25km N/E, they have a big shooting range with associated Danger zone, virtually impacting nobody (even if things go wrong).
FI554 KEF-BRU had to turn back to KEF after a sticking valve in deicing system.
United UA-973 Brussels-Chicago diverted to Shannon.
Reason: fuel leak:
http://avherald.com/h?article=4cf6ff86&opt=0
lucas
Post by lucas »
A Cityjet CRJ900 operating SN2045 from Brussels to Birmingham is returning to Brussels. It flew a few circles above the North Sea to lose some weight.
TUI fly Belgium’s Boeing 787-8 Dreamliner stuck in Cancun, Mexico after technical issue
Around 300 passengers got stranded in Cancun, Mexico after a technical issue with a TUI fly Belgium Boeing 787-8 Dreamliner (OO-JDL). On 18 November – three days ago – the aircraft uneventfully departed Brussels, Belgium towards Cancun, Mexico. The holiday airline, however, was forced to cancel the return flight after a problem with the aircraft’s rudder. While passengers were accommodated in a hotel, a spare part was flown in to fix the technical issue. Subsequently, the passengers are expected to return to Belgium this evening, spokesman Piet Demeyere confirmed to Belgian newspaper Het Laatste Nieuws.
https://www.aviation24.be/airlines/tui- ... cal-issue/
TB-352 18 Nov Cancun-Brussels OO-JDL is finally airborne:
https://www.flightradar24.com/data/airc ... l#22ec90ca
21 Nov 2019, 20:45
It is strange that Het Laatste Nieuws talks about 350 passengers when the capacity of TUI's 787 is 300 passengers.
