TUI fly Belgium in 2019
Re: TUI fly Belgium in 2019
TLspotting wrote:
11 Feb 2019, 18:05
Someone btw at Salon des Vacances at Brussels this weekend, at Lille Airport stand told me a Boeing 787 of TUI was coming today or tomorrow to Lille... But it seems more that a DREAMLINER flight is planned for Wednesday or so...
Most likely, the 787 will divert to Lille due to the national strike in Belgium.
11 Feb 2019, 20:39
TLspotting wrote:
11 Feb 2019, 18:05
OO-LOE to LIL and JDL to ORY
TUI Belgium today published the favourite destinations by air from Belgium for the mid-winter holidays:
1. Spain (including the Canary Islands)
2. Egypt (doubles compared to 2018)
3. Morocco
4. Cabo Verde
5. Dominican Republic (40% more than in 2018)
...A TUI Airlines Belgium Boeing 737-800 on behalf of Sunwing, registration OO-SRO performing WG-326 (dep Feb 17th) from Varadero (Cuba) to Ottawa,ON (Canada) with 190 passengers and 6 crew, was climbing through FL150 out of Varadero when the crew received indication of low pressure on the right hand engine (CFM56) hydraulic system B...
Continues here:
http://avherald.com/h?article=4c4da41c&opt=0
02 Mar 2019, 10:24
Continues here:
190 pax? The maximum capacity is 189 pax! Where did the 190th sit?
There’s a maximum of 189 seats on a 737-800. That doesn’t mean the maximum passenger capacity is 189, though.
You can still put an infant on the lap of an adult.
In fact, dependant on configuration, the maximum number of passengers, including infants, on board could theoretically be somewhere close to 250, if enough infant life vests and seat belts were loaded.
So yes, 190 would very much be possible.
TUI Netherlands PH-TFC 737-800 (NG) will have a C-check at Luton, and will then join TUI Belgium.
https://www.airfleets.net/ficheapp/plan ... -35146.htm
To make optimal use of its fleet during the less busy winter season in Europe, TUI fly Belgium is operating charter flights from Canada and the United States. A total of eight Belgian registered aircraft (and Belgian crews) are flying tourist goers to and from exotic – and warmer – destinations.
https://www.aviation24.be/airlines/tui- ... ed-states/
Bralo20
Post by Bralo20 »
08 Mar 2019, 11:47
This year while keeping their Belgian registrations or re-registered like other years?
Bralo20 wrote:
08 Mar 2019, 12:13
08 Mar 2019, 11:47
I checked on airliners.net and found OO-JEF at Cancun, Mexico. The registration hasn't been altered:
http://www.airliners.net/photo/Jetairfl ... K5/5393329
08 Mar 2019, 12:32
Bralo20 wrote:
08 Mar 2019, 12:13
08 Mar 2019, 11:47
And hereabove OO-SRO has been mentioned as well: viewtopic.php?f=7&t=64660&start=20#p378628
02 Mar 2019, 10:24
Continues here:
Two days later, the same aircraft had a similar incident:
Incident: TUI Belgium B738 near Ottawa on Feb 20th 2019, hydraulic failure
A TUI Belgium Boeing 737-800 on behalf of Sunwing, registration OO-SRO performing flight WG-425 from Punta Cana (Dominican Republic) to Ottawa,ON (Canada) with 177 passengers and 6 crew, was descending towards Ottawa when hydraulic system B failed. The crew declared PAN PAN and continued for a safe landing on Ottawa's runway 07 about 13 minutes later.
https://avherald.com/h?article=4c56160b&opt=0
TUI fly Belgium suspends the Charleroi - Essaouira route in Summer 2019.
Nicolarson
Post by Nicolarson »
When is the 737-800 coming back from the USA?
Thank you :-)
Welcome to Aviation24.be, Nicolarson!
Nicolarson wrote:
22 Mar 2019, 14:32
Thank you :-)
Not one, but four 737-800s are leased to the US and Canada. Normally they come back at the end of the winter season.
Nicolarson wrote:
22 Mar 2019, 14:32
Thank you :-)
All by the end of april
Miami Air International and Sunwing... Now Sunwing need them as well due to MAX restrictions...
OO-JDL once again stuck... at Cancun this time, being replaced by a Spanish Wamos Air Airbus A330.
B38M and B39M are banned from Belgian skies for commercial ops until 27JUN.
A0999/19 NOTAMR A0990/19
Q) EBBU/QAFLP/IV/NBO/E /000/999/5029N00411E999
A) EBBU B) 1903271107 C) 1906271200 EST
E) BOEING 737-8 MAX AND BOEING 737-9 MAX PROHIBITED IN BELGIAN
AIRSPACE EXC NON COMMERCIAL FERRY FLT.
REF THE CIVIL AVIATION AUTHORITY IN EXERCISE OF ITS POWERS IN
ACCORDANCE WITH REGULATION (EU) 2018/1139 ARTICLE 70
CREATED: 27 Mar 2019 11:08:00
SOURCE: EUECYIYN
Doesn't look too good but OK, a NOTAM can always be amended/cancelled when needed.
