Anomalies in BRU-ANR-CRL-LGG-OST in 2018
Re: Anomalies in BRU-ANR-CRL-LGG-OST in 2018
Post by luchtzak » 17 Nov 2018, 00:54
16 Nov 2018, 23:41
Fog at BRU now?
Aeroflot SU-2618 diverted to AMS:
https://www.flightradar24.com/data/airc ... b#1e9398fb
No clue why, but foggy indeed ...
EBBR 162320Z 07001KT 0300 R25L/0375N R25R/0600N R01/0450N FG BKN001 00/00 Q1027 BECMG 1000 BR
Post by TLspotting » 17 Nov 2018, 18:40
What's happening at BRU with 01/19 and 25L/07R closed due to "work in progress"?
I'm Thibault Lapers, spotter in Belgium for now 3 years, but not yet across the world and a huuuuuge aviation geek ! Join me on Facebook & Twitter @TLspotting
ZavCity
Post by ZavCity » 17 Nov 2018, 19:36
Works are finished earlier, due to good weather conditions
gtz
paul
Post by KriVa » 17 Nov 2018, 21:06
True, but today some other works were performed on 25L and 01, hence necessitating 07L/25R single.
Due to the wind, 07L was chosen.
Post by Passenger » 26 Nov 2018, 14:41
24th Nov 2018, LGG: ASL Airlines 747-400F OE-IFD bird strike during take off, emergency call and return to LGG:
see this topic:
https://www.aviation24.be/forums/viewtop ... 38#p375164
Post by sn26567 » 28 Nov 2018, 18:29
Post by Passenger » 12 Dec 2018, 07:15
On 11th December 2018, OO-SFU (A330-200) performing flight SN-358 (dep 10th Dec) from Kinshasa to Brussels, was enroute at FL380 over Algeria when the left hand engine failed prompting the crew to drift the aircraft down to below FL270. The crew was able to re-start the engine in flight, climbed back to FL380 and continued the flight to Brussels.
Source - more info:
http://avherald.com/h?article=4c170682&opt=0
Flight on FR24:
https://www.flightradar24.com/data/airc ... u#1ed3a3bd
Post by Passenger » 12 Dec 2018, 23:45
Cracked windshield for a Bulgaria Air ERJ-190 Brussels-Sofia:
http://avherald.com/h?article=4c17adc8&opt=0
domtom
Post by domtom » 17 Dec 2018, 12:22
This little jet took off in Nuremberg and has been flying low altitude for a while. Anyone knows what he's up to? Taking pics? Sampling the territory?
Post by jan_olieslagers » 17 Dec 2018, 13:16
I couldn't say, but he is mighty close to violating the reserved airspace around the NATO installations at Casteau... Photography seems little likely, but perhaps (procedural) training?
NB if you have ever stood next to a CL604, you won't call it a "little" jet anymore :)
Post by DIBO » 17 Dec 2018, 14:34
Based on the screenshot, an approach or two on EBCV's rwy 26 was part of the flight.
Post by DIBO » 17 Dec 2018, 18:39
domtom wrote:
17 Dec 2018, 12:22
A navaid calibration flight at Chièvres Air Base, similar to these guys
A modified CL-60 Challenger aircraft, flown by Airmen from the Air Force Flight Standards Agency, makes a low-level approach April 10 past the new instrument landing system antenna at a Southwest Asia airfield. The aircrew used on-board instrumentation to calibrate the ILS and ensure the navigational aid meets standards. (U.S. Air Force photo /Airman 1st Class Gustavo Gonzalez)
Post by jan_olieslagers » 17 Dec 2018, 18:57
Well if they were US'an (or at least NATO), as I suspected, that would explain they knew what to do to legally cross the SHAPE airspace. Why they wanted to fly there is still a bit of a mistery...
Also, if they can afford to use a jet for this type of flight, I can see no lack of military budgets :roll: Even EBBR Zaventem uses a modest King Air for that job - at those altitudes, jets are not terribly efficient.
domtom
Post by domtom » 17 Dec 2018, 21:34
jan_olieslagers wrote:
17 Dec 2018, 13:16
Thanks. I thought so as well. Perhaps a regular training flight.
So does Chievre airport serve NATO, then? Of who?
Thanks
domtom
Post by domtom » 17 Dec 2018, 21:36
17 Dec 2018, 18:57
Thanks to both of you. Makes alot of sense. Was the aircraft just based in Nuremberg then? And would this be a NATO plane? And new ILS Équipment?
Post by jan_olieslagers » 18 Dec 2018, 05:58
Chièvres is a USAF base, it mostly serves VIP transports (check it out on Wikipedia).
Most likely the plane was from the USAF, too, that should be visible from FR24.
And not necessarily new ILS equipment: calibration must be done periodically, perhaps once per year or so.
dcoops
Post by dcoops » 18 Dec 2018, 06:19
It was N88, a CL604 registered to the FAA
Post by Passenger » 19 Dec 2018, 18:26
DIBO wrote:
19 Dec 2018, 12:11
Flybe's BE6031 (operated as Stobart STK5AM) Groningen-Southend, returned a few minutes after departure back to GRQ
This plane was scheduled to fly the SEN-ANR leg afterwards, so this flight has been delayed considerably.
Landing gear issue ("could not retract landing gear").
The aircraft positionned to Southend as STK61P, so probably without passengers:
https://www.flightradar24.com/data/aircraft/ei-fmk
... and this one took over SEN-ANR-SEN
https://www.flightradar24.com/data/aircraft/ei-fmj
Robby
Post by Robby » 21 Dec 2018, 09:20
SN3779 (OO-SNF) on route to Tenerife made a u-turn back to Brussels, and is currently on final to RWY 19
Av24.be
Post by Av24.be » 21 Dec 2018, 11:15
Robby wrote:
21 Dec 2018, 09:20
A strange smell in the cabin: https://www.aviation24.be/airlines/luft ... the-cabin/
