We might be better off to wait for the official time table before speculating on what connections will all be possible, but if this flight doesn't go daily, I think it will focus on the local market at both ends first, as well as short haul connections only.Stij wrote:I doubt they'll connect to a lot of the Africa flights as due to the NRT curfew, they cant depart between 23:00 and 6:00.'
So either they'll depart NRT at 23:00 and arrive in BRU at 3:30... not...
either they'll depart at 6:00 and be in BRU at 10:30... close connection in BRU, but no connections in NRT,
or they'll use there first wave at 10:00 in NRT and arrive in BRU around 14:30... maybe some connections to West Africa. But then the aircraft won't fly back to NRT before 16:30 and then the connections from Africa to Japan are too long...
My bet: no connections to Africa, but connections in NRT to the rest of Japan or...
OTOH, the tweet from BRU this moring mentioned a DAILY flight, so who knows, they might surprise us even more??? In that case, connections to Africa might also be something which have to be taken into account indeed for deciding on a perfect schedule.
If I remember well, somebody (Atlantis???) mentioned some time ago the aim was for an evening flight out of Tokyo.
If indeed they stick to that initial plan, that would set them for a very early morning arrival into BRU then, with a return flight to Japan a couple of hours later; that's all fairly similar to how the US flights operate at BRU in fact, no? That kind of arrival/departure times offer good connectivity to both Brussels Airlines European as well as African destinations, so no idea why it couldn't be for this flight too then?
Maybe they have to keep the plane waiting a couple of hours extra on the ground in BRU to make it all work out with the night closure of the airport in Tokio and the connectivity, but my bet is this is a premium heavy route, so if they have to do just that, they'll do it: it's likely not the kind of route where the average passenger really cares about the odd 50 or 100 euro more if it gives him an optimised time table in return, so they may be able to pass the extra ground time on to their customers, if needed.
Not to mention this is the kind of 'project problem' BRU could help them solve during the negotiations with them, for instance by not charing them for the extra ground time.
BTW- does anybody know how ANA decides on the airport to operate its Tokio flights from?
Because I see that some flights to Europe (CDG, DUS for instance) are from Narita, whereas others are from Haneda, but on what basis is this decided? And why Narita for their BRU route? Would be cool to know, even if it doesn't really matter much. Thank you!
