Now Lufthansa does not expect its fist B777-9 before 2Q 2022.
Boeing 777(X) news
Re: Boeing 777(X) news
Boeing CEO David Calhoun just gave a warning of sorts about the Entry into Service of the 777X. Already pushed back to 2022, he said certification could push it back further. FAA seems to have learned the lesson!
Launch customer Kalitta Air leases three Boeing 777-300ERSF from GECAS Cargo
https://www.aviation24.be/airlines/kali ... cas-cargo/
ANA Holdings has agreed with Boeing to delay its first B777-9 by two years to fiscal 2023. This follows delays on orders for the A380 and B787.
Emirates president Tim Clark said the Boeing 777X might not enter into service with airlines until 2023 or even later, amid uncertainty over the development timeline.
Boeing says that 118 orders for its B777X plane under development are no longer seen as firm under ASC 606 accounting rules that require it to regularly assess their viability, leaving it with only 191 solid orders for the model.
Boeing is recommending air carriers halt flights of B777s until the FAA issues inspection protocols, following an engine failure mid-flight.
https://www.aviation24.be/manufacturers ... ng-debris/
US regulators announced extra inspections on B777 jets using the same type of engine that shed debris over Denver, while Japan went further and suspended their use while it considers what action to take.
United Airlines is “voluntarily and temporarily” halting flights of B777s with P&W 4000 engines, affecting 24 active jets after an engine fire erupted mid-flight.
Eastern Airlines seeks approval to increase its total fleet from 10 to 18 aircraft and to use eight aircraft for scheduled operations. Eastern has purchased two B777-200ERs with planned EIS during 2Q 2021. Eastern will also be leasing two B777-200Fs to operate ACMI charters. Not sure acquiring B772s now is a good idea...
My understanding is that only those B777 equipped with PW4000 engines are affected by this grounding (as mentioned on the home page).sn26567 wrote: ↑22 Feb 2021, 17:46 Boeing is recommending air carriers halt flights of B777s until the FAA issues inspection protocols, following an engine failure mid-flight.
Only the original B772 and B773 were proposed with three types of engines : GE, PW and RR.
All B77L (B777-200LR), B77W (B777-300ER) and B777F are proposed only with the GE90-110 or -115. So these aircraft are not concerned.
