Has the decision already been made to build an extension of the A-pier to the west ?Conti764 wrote:but when A-pier West is finished
Brussels Airport to extend the A-pier ?
In favor of quality air travel.
Re: brussels airlines to New York!
Hi Air Key West,Air Key West wrote:I's off topic, but has the decision already been made to build an extension of the A-pier to the west ?Conti764 wrote:but when A-pier West is finished
Yes the decision is made. Some time ago Brussels Airport communicated this officialy that the extension to the West will come (it is very needed) and a new "connector" from the Terminal to the Pier A.
If everything goes according to plan, then the extension should be finished in 2015.
In this masterplan also the extension of Brucargo is involved and the refurbishment of the old Terminal building which is called "The Gateway".
Thanks, Atlantis. I remember now that you have refreshed my memory. So, it's going to be at least another five years of hardship for those with long connection times to Africa, especially from JFK with b.air which is the first flight from the US to arrive at BRU, but it's a first flight for b.air. Let's assume things/flights will improve with time.
Re: Brussels Airport to extend the A-pier ?
If it is to be finished in 2015, and tomorrow is 2012, isn't it only 3 more years? (if all goes according to plan...)
Any idea on when these projects will start (The Gateway, Connector, A-pier West,...)? In 2012 I assume (at least for a part of the projects), but more already more details?
btw, weren't there also plans to finish the underground bagage system of the A-pier? Don't know much about that, but wasn't this build for Sabena but never finished after they went bankrupt? I tought I heard something about that earlier this year that they want to finish this right now to accomodate the hub activities of SN/Star...
- Airbus330lover
It seems the A Pier underground luggage system is finished but never used (fine tuning never done !)
It has been tested several times, though.
But indeed, never actually put in service.
Greetz,
Greetz,
Actually, this seems like something typically Belgian to me.Airbus330lover wrote:It seems the A Pier underground luggage system is finished but never used (fine tuning never done !)
Actually I heard they never used it because they never really needed anymore after the collapse of Sabena (and the A-pier was not finished before the collapse of Sabena). Because after that there was no airline really operating hub activities at the A-pier in BRU and made the underground system not really necessary. This now changed with SN/Star Alliance.WC_EEND wrote:
So any idea if (and if yes, when) this system will be taken into service?
Thanks Mr Boeing for bringing things back into perspective.
As the Sabena collapse occured 6 months prior to the opening of the A Pier, a great deal of the equipment was already installed, the civil works were done for some time and of course the master plan was set years ahead.
If I remember correctly, the traffic pattern included 30% transfer. This went down to less than 3% overnight.
In early November, all contractors were requested to value several options :
The BHS had its own trouble, running over cost and late, so that didn't help as it represented a major cost item in the global project.
The system has then been limited to part of the Pier, till about the drive-through at stand 159 or so, coming from the Topaz and the muti-conveyor tunnel (that delayed opening of stand 143 for months) across the apron, alongside the pax tunnel.
Let's hope the BHS will be finnaly used some time in the future.
- - penalty for cancelling the contract as is and stopping any further deliveries/installations.
- penalty for revision of scope
- continuing with the full scope and planning, but with additional cost for mothballing the equipment including preventive maintenance to keep it in operational condition until hell freeezes over.
The underground bagage system is finished already since a couple of years. The total investment was 20 million euro.MR_Boeing wrote:btw, weren't there also plans to finish the underground bagage system of the A-pier?
But then some problems in aviation appear and they had more then enough capacity with the current system under the Terminal.
Goal is to use this own new system with the opening and the use of the new extension of Pier West.
Then they will need this system badly.
When this is operational they can refurbish and updated the current one.
