Two Jetairfly-flights are delayed quite long today:
JAF502, incoming from Cancun/Varadero: ETA was 06h30 - now delayed till 02h05 (767)
JAF6003, outgoing to Malaga: ETD was 06h15 - flight took off at 18h10 (737)
JAF6004, incoming from Malaga: ETA was 12h40 - now delayed till 00h55 (737)
Are both delays related ?
Sat 01 Nov : two long delays for JAF
Re: Sat 01 Nov : two long delays for JAF
JAF502P PHMCG is on the way to Varadero to replace OOTUC.
Mirror
Well, the JAF502 Cancun/Varadero isn't in Brussels Airport' Flight Info anymore. Could this mean that OO-TUC is in serious trouble in VAR?
Other delays (exlcuding those, less then 4 hours):
JAF6632, SSH-BRU: ETA 02h25, delayed till 09h10 (737)
JAF7628, SSH-BRU: ETA 14h20, delayed till 23h35 (767)
- Darjeeling
LX, please enlighten us: What compensation can the passengers of those flights ask ??
On 3/11 (brusselsairport.be) JAF502 1105 Delayed 0545
With some luck passengers arrive on tuesday
Mirror
brusselsairport, if PH-MCG (Martinair 767) indeed has been sent to Varadero Saturday evening, JAF502 should be back in BRU on Monday morning, not Tuesday morning.brusselsairport wrote:On 3/11 (brusselsairport.be) JAF502 1105 Delayed 0545
Perhaps it was an input problem for BRU's website?
PH-MCG/TUB 502 is about to depart VRA for CUN at this moment, but is not scheduled to return to BRU until tuesdaymorning at 0530lt. I would suspect that is because of legal crewrest requirements.
The Flemish newspaper Het Laatste Nieuws now reports that hundred Jetair-passengers are blocked in TLV since last Thursday. Added by another hundred since Sunday. They're awaiting their flight to LGG.
Article (sorry, Dutch only):
http://tinyurl.com/5hppj2
And today's JAF103 to MUB/POP is delayed from 06h05 to 17h40...
Mirror
.......and JAF7162 from TLV to LGG, supposed to land in LGG at 20:40 has been delayed to 21:40 and than to 23:00 ...............
Well, the Ben Gurion website now indicates that JAF7162 has finally left for LGG at 20h06 local (= 19h06 Belgian time).an-148 wrote:.......and JAF7162 from TLV to LGG, supposed to land in LGG at 20:40 has been delayed to 21:40 and than to 23:00
JAF 7162 LIEGE 03/11 00:35 20:06 3 DEPARTED A 24-27
TLV search engine for departures:
http://www.iaa.gov.il/Rashat/en-US/Airp ... rDFlight=D
edited after posting : has finally left for BRU ... has been corrected into ... LGG...
Message for VTM (Flemish television):brusselsairport wrote:On 3/11 (brusselsairport.be) JAF502 1105 Delayed 0545
arrival JAF502 is now confirmed for Tuesday, 06h50. Almost 3 days too late indeed.
So after all, it seems that did not sent a Martinair 767 to Varadero/Cancun, but just waited till OO-TUC was fixed.
- Bruspotter
It's really a pity that the OO-TUC is again in some bad publicity after it had gone very well for a wile. I'm curious what whas the problem this time.
Best regards, Yannick
JAF7162 landed at 23:21 in LGG
And JAF502 landed at 06h47 in BRUan-148 wrote:JAF7162 landed at 23:21 in LGG
(3 days too late)
From what I've heard, the OO-TUC had a problem during pushback. One of the main wheel broke. The whole wheel, brake and tire were u/s !! A team was sent and repaired it on Monday.Bruspotter wrote:Hello
JY
Odd. According to my info JAF502/PH-MCG arrived in BRU this morning at 0647lt with 213 pax on boardLX-LGX wrote:
It must be more than just that. Replacing a wheel takes about half an hour, same thing for a brake assembly. Perhaps a wiring fault or hydrolic line damage?CaptJY wrote: The whole wheel, brake and tire were u/s !! A team was sent and repaired it on Monday.
JY
Negative, the Martinair did in fact fly the passengers back. Odd conclusion you make out of that story...LX-LGX wrote:So after all, it seems that did not sent a Martinair 767 to Varadero/Cancun, but just waited till OO-TUC was fixed.
The Martinair 767 left for Varadero on Saturday evening, so it could have been back in BRU already on Sunday evening - or at the latest on Monday noon. But then indeed, I was wrong, I'm sorry: I was wrongly thinking that JAF would try to get the pax back home as soon as possible, even it that would mean a double Martinair crew.JAFflyer wrote:Negative, the Martinair did in fact fly the passengers back. Odd conclusion you make out of that story...LX-LGX wrote:So after all, it seems that did not sent a Martinair 767 to Varadero/Cancun, but just waited till OO-TUC was fixed.
Anyway : trust the pax preferrred PH-MCG above OO-TUC for their return flight, don't you think so?
