The FAA orders immediate inspections of leading-edge slats following the China Airlines B738 accident.
Other entities will probably follow.
http://www.flightglobal.com/articles/20 ... 37ngs.html
Every B737NG needs to undergo an emergency slat check
Fly4hours, making the path to airline pilot affordable to all
According to Flight International, the problem is more than an isolated instance, and FAA have issued a new AD requiring compliance much sooner.
One bird apparantly had a pierced slat can like the China Airlines did, but not obviously as serious.
Like you said, so often it is the simple things!
Cheers
Achace
Cheers
Achace
the problem about loose bolts exists already since industry used bolts, let's say 200 years ago.
All kind of remedies have been doctored out, new inventions hit the market, but still bolts get loose.
I have no doubt that Boeing has a major division going about nuts and bolts. And when this happens, it makes people wonder what really happened. Could weight saving been an issue, by dropping washers and special nuts that can not get loose? Or was it the price? China?
I have no doubt that bolts in airplanes are assembled using specific tools with torque wrenches. But these special tools are expensive as well. You can buy such a tool in a DIY-store for 3-5$. But exactly the same tool from a renowed source costs 50-500 $ !
Have a look at the website of FACOM, a renowed name.
www.facom.com
At the bottom of the first page you see they had a stand at Le Bourget with...a special torque wrench.
So it is a very common issue in aircraft manufacturing.
www.facom.com
So what I read in Airliners.net seems to confirm it: a simple loose bolt, defect washer, missing nut.
And the inspections start to show very negative results. So it is not a single case of somewhere a mechanic with a hangover . It is a manufacturing issue. Maybe a design issue as well, of using a wrong construction in an environment of vibrations + large temperature changes ( expanding + shrinking makes standard bolting loose )
pressman wrote:European airplanes have to be inspected under the FAA directive as well , as the US is the state of Manufacture
Infact it's a EASA Emergency AD that is issued for European registered Boeing 737- 6/7/8/900 aircrafts.
The directive can be found : here on the EASA site
They speak about an other operator that found fuel leaking out a drain hole at slat 5 track.
I think this will have a big impact , maybe boeing will have to redesign the whole assembly.
by the way , a lot of Facom "Aeronautic tooling" is crap !
