Tx for all the contributions last month.
A new one has arrived, so again opportunities to share your (pictorial) sightings.
Contrail spotting November 2010
- contrailwatcherUK
- contrailwatcherUK
Re: Contrail spotting November 2010
Photos from today:
UAE211 A6-EMC
VIR27 G-VAST
AUA87 OE-LPD
RA-82045, descending into Yeovilton
UAE211 A6-EMC
VIR27 G-VAST
AUA87 OE-LPD
- leedseagle
Hi there
A few from Sunday with Barlow and new fan (to ventalate scope) fitted for the winter
Flybe heading north
ICE543 B757 38000FT Heading 330* TF-FIA CDG-KEF
USAF on Contrail Heading Southeast
AF084 CDG-SFO A340 Heading 332* F-GLZJ 30000ft
Air Tahiti Nui THT7 CDG-LAX-PPT A340 Heading 332* F-OJTN 32000FT
All the best
Leedseagle
Flybe heading north
All the best
Leedseagle
8" Skywatcher Dobsonian, Revelation 2" ED Barlow, Canon EOS 500d, Nikon Coolpix P900, Uniden EZI33XLT, Celestron Skymaster 25x75 Binoculars
http://www.flightradar24.com https://contrailspotting.wordpress.com
- contrailwatcherUK
Fantastic shots Leedseagle, the Air France A340 is pin sharp!
- leedseagle
Cheers mate had a few probs with weight of camera pushing focuser back down so phoned up Telescope house and they told us to tighten middle large allen screw that should hold it and it did the trick also fitted an 80mm fan to a disk suspended below primary mirror blowing air up the tube. Very pleased with the results
All the best
Leedseagle
All the best
Leedseagle
- contrailwatcherUK
Sorry for the quality but this happened pretty fast, Delta 173 creating some awesome clouding effects. En-route JFK-Narita Int'l
could you guys post the equipment you are using too? thanks
Free amazon gift cards each month!
http://swagbucks.com/?cmd=sb-register&rb=262147
Hi to you,
A few more photos from today,------Had a cold star(-1c)and hazy blue sky put humidity was 76%.
I had moisture over the scope,finderscope,primary mirror and the camera and i lost a lot of photos due to the moisture.
ALL photos taken with barlow.
KATITTA AIR BOEING 727-221F N748CK GOING EAST ON AIRWAY UL607
OMNI AIR DC-10-30(IN NEW COLOURS)GOING EAST ON UL607
CARGOLUX BOEING 747-400 GOING EAST ON UL607
UNITED A/Ls BOEING 777 ALSO GOING EAST ON UL607
SORRY ABOUT THE QUALITY OF THE PHOTOS
All the best to you all
DC10MD11
DC10MD11
Hi to you all,
A few more photos which i took on the 19th november.Had nice blue sky and later high white cloud come over.
Only some aircraft on contrail and all photos taken with barlow.
i had moisture over the main mirror so i took the scope indoors,undone the screws at the back of the scope and took the mirror out and washed it under the shower(1st time in 2 years) and then with de-ionised water and then used the wifes hairdryer to dry it and reinstalled it back in the scope.Checked the anlinement with the lazer and it was still spot on.
Had to wait a hour or so for the scope to cool down to the out side temperture.
result=NO MORE MOISTURE
The 1st and 2nd photos have been taken AFTER the mirror was re-installed--a inprovement. .
DELTA A/Ls,, BOEING 747-400 ,, N673US,, DAL8956,, COLUMBIA-METROPOLITAN TO HAHN,GERMANY -- ROUTING EAST ON AIRWAY UL607
AER LINGUS-------EI-CVD----------AIRBUS A320------- -----ROUTING EAST ON AIRWAY UL9.
BOEING 747-200 (E4B---THEIR ARE ONLY 3)-------73-1676:D OF THE USAF ROUTING EAST ON AIRWAY UL607 AS HUGE 25.
(IN THE WHITE CLOUD )
KALITTA AIR--- BOEING 747-200------- N708CK-------- ROUTING EAST ON UL607 TO BELGIUM,------,29.000ft.
KLM MD-11--------PH-KCG---------- KLM713----------ROUTING WEST ON UL607------,,--AMS-ZANDERIL,,---30.000ft.
CONTINENTAL A/Ls----- BOEING 767-400---N69059---ROUTING IAH-FRA-----35.000ft---UL607.
BELGIUM A/F----CD-01------FALCON 900B------ ROUTING EAST ON UL607 AS BAF631.
AIR TRANSAT AIRBUS A330---C-GTSN------- ON DELIVERY AS TSC 11 ZRH-YUL--- AT 40.000ft ON AIRWAY UM733.
ETIHAD-------AIRBUS A340-600---A6-EHJ---ROUTING EAST ON UL607 AS ETD150----ORD-ABU DHABI--36.000ft.
ETIHAD-----BOEING 777------ROUTING EAST ON UL607.
ROYAL JORDANIAN AIRBUS A340-300---JY-AIC--ROUTING EAST ON UL607 AS RJA268--DETROIT/MONTREAL/AMMAN--36.000ft.
LURTHANSA BOEING 747-400 D-ABVC ROUTING EAST ON UL607 AS DLH400 JFK/FRA 33.000ft.
BMI BABY BOEING 737-300 G-TOYD ROUTING EAST ON UL9 AS BMI59M 35.000ft.
OMNI AIR DC-10 ROUTING EAST ON UL607(NO DETAILS)
Would like to say thank you to sky-stef for some of the details .
All the best to you all,
DC10MD11
DC10MD11
Hi to you all,
Just got back from work today AT 13.15GMT and i saw a AN-12 ON CONTRAIL ROUTING EAST TOWARDS DOVER ON AIRWAY UL607/UL9.---------------The A/C looked LIGHT BLUE at about 20.000ft.
NO PHOTO due to scope in doors and 90% cloud cover.
CAN ANY ONE HELP WITH THE I/D OF THIS AIRCRAFT??????????????????????Was NOT ON rader.
Many thanks
DC10MD11
Many thanks
DC10MD11
Hi
I have UR-DWF AN12 recorded between 12:46 & 13:26, callsign MEM4055 at 27000ft
One question! What equipment do you use for contrail?
Ian K wrote:Hi
Hi
Many thanks to you for the details .
All the best to you,
DC10MD11
Fire Boss wrote:One question! What equipment do you use for contrail?
Hi
Use the link below, this should help you.
http://www.skystef.be/contrail.htm
All the best
DC10MD11
Hi
I have only just purchased a scope so I am still learning
Here is the best photo out of a bunch I took the other day.
PH-KCK MD11 KLM757 Heading West over North London at FL300
Ian
Ian
Ian K wrote:Hi
Ian
Hi ian
Nice to see your photos------also seen your photos on the SBS website.
Are you using the barlow lens???????????????????.
Have been out today(days holiday)with the scope and the sky is clear put cloud has moved in.Will put the results on in a few days.
Have you tryed using the AV settings on your camera!!!!!!!!!!!!!!!!!.
All the best
DC10MD11
HiDC10MD11 wrote:
Hi ian
All the best
DC10MD11
No not used the Barlow lens yet.
I have been using the Tv setting on the camera because when I put it on AV it shows as 00 because there is no lens on the camera, but I will try it next time we get some blue sky
Do you post on the SBS site ?
Cheers
Ian
Hi to you all,
A few more photos which i took on monday 29th nov.------Had a nice clean sky untill the cloud rolled in.
ALL Photos taken with BARLOW ------+it was cold +1.
SINGAPORE A/Ls BOEING 747-400C 9Q-SFP ROUTING EAST ON UL607 AS SQC7953---- SINGAPORE/DALLAS/BRUSSELS, 29.000FT. Many KMs away.
AIR FRANCE BOEING 777-200 F-GSPC ROUTING NORTHWEST ON UM733 AS AFR028,CDG-DALLAS
AMERICAN A/Ls BOEING 757 ROUTING NORTHWEST ON UM733.
TUI-FLY BOEING 737 ROUTING WEST ON UL607.
CONTINENTAL BOEING 767 GOING NORTHWEST ON UM733.
CESSNA 510 CITATION MUSTANG G-KLNW c/n 510-0157 SAXONING CHARTER LTD ROUTING SOUTH.
AIR TRANSAT AIRBUS A330-300 C-GKTS ROUTING NORTHWEST UM733 AS TSC711 36.000ft CDG-MONTREAL.
US AIRWAYS AIRBUS A330 ROUTING NORTHWEST ON AIRWAY UM733.
KLM BOEING 777 PH-BQH ROUTING WEST ON UL607 AS KLM743 30.000ft AMS-LIM..
KALITTA AIR BOEING 747-200F N700CK ROUTING EAST ON UL607 AS CKS249 NEWARK/BRUSSELS.
AIR FRANCE BOEING 777-200 F-GSPP ROUTING NORTHWEST ON AIRWAY UM733 AS AFR636 CDG-HOUSTON, 32.000ft.
FLYBE DASH 8 ROUTING EAST ON UL607 MANY KMs AWAY ON CONTRAIL .
AIR FRANCE AIRBUS A340 F-GLZC ROUTING NORTHWEST AS AFR012 CDG/JFK 34.000ft.
HIGH LIGHT OF THE DAY WAS THIS BELGIUM A/F C-130H HERCULES ROUTING EAST ON AIRWAY UL607.
(ON CONTRAIL )
AIR FRANCE AVRO RJ85/BAE 146-200 EI-RJR ROUTING NORTHWEST ON UM733.
THOMSON BOEING 757 ROUTING EAST ON AIRWAY UL9.
LUFTHANSA AIRBUS A340 ROUTING EAST ON UL607
KALITTA AIR BOEING 747-200F N704CK ROUTING EAST ON UL607 AS CKS329 NEWARK/BRUSSELS.
Here in the southeast of england-it is snowing and at night time it is -6 .....................
Thats it for now---hope you like photos.
All the best
DC10MD11
(ON CONTRAIL )
All the best
DC10MD11
