CRL 29/07/2020
CRL 29/07/2020
Post by sdbelgium »
1435-1700 E55P DCDAS
Re: CRL 29/07/2020
I was wondering why the two Air Corsica A320neos with respective destinations Bastia and Ajaccio are heading Horth after take-off from Rwy 24, rather than flying South immediately? (Both planes are on the attached figure)
Re: CRL 29/07/2020
Post by sdbelgium »
The first thing that comes to mind is the activation of military airspace south of the airfield (I think that’s Chievres area?).
Re: CRL 29/07/2020
You are right. I see the RYR flights to FAO and ACE (with my daughter onboard) as well turning Northwest before going South. There seems to be a no-fly zone which might indeed be Chièvres.
Airbus330lover
Re: CRL 29/07/2020
Post by Airbus330lover »
Quite normal :
CHIEVRES MIL EXER 503500N 0035000E RADIUS 15NM.
ACFT CONDUCTING LOW LEVEL TACTICAL MANEUVERS.
Lower limit: GND Upper limit: 2500FT AMSL
Re: CRL 29/07/2020
Airbus330lover wrote:
31 Jul 2020, 10:47
Quite normal :
Thanks for clear explanation.
Re: CRL 29/07/2020
Post by DIBO »
I'm sorry to spoil the fun :-) , but for Corsica the route via Luxemburg is the normal route, and the clockwise turn after T/O rwy 24 is normal with Florennes active. The Chievres restriction is way too low (2500ft) to have any impact on these flights and was even not active the 29th. The ACE and FAO flights on that day went the usual route via Chievres, if I'm not mistaken. In my opinion we must 'blame' the Tiger & Viper flights (F16's).
spottermm
Re: CRL 29/07/2020
Post by spottermm »
Indeed those are normal routes when Florennes is active. At EBCI they use SIDs « Y » when in use (via the north) and « U » when not active (via the south)
