Aviation24.be uptime/downtime topic
Give your feedback, make new suggestions to improve https://www.aviation24.be, is there anything else we can do for you?
Re: Aviation24.be uptime/downtime topic
Post by luchtzak » 29 Aug 2019, 19:04
Aviation24.be is currently invaded with a specific crawler, causing high load to the server. Pages are also loading slower than expected. Rest assured that we are putting all our effort in to reduce the server load and to optimize the website ASAP.
Post by luchtzak » 30 Aug 2019, 01:53
29 Aug 2019, 19:04
An out-of-control crawler called BLEXBOT opened over 800 sessions in the forums. We have now blocked a series of IP-addresses from our forums. In case you don't have access to the forums, please contact us.
Post by luchtzak » 19 Dec 2019, 10:36
Past hour, we are facing a high load issue on the server. The website is hard to reach. Keep you posted!
Post by luchtzak » 25 Jan 2020, 11:28
Lots of bot-sessions are opened in the forums, causing a high peak on the server. We are closely monitoring the situation.
Post by jan_olieslagers » 26 Jan 2020, 10:31
Webpage was unavailable early this morning, was back again at +/- 9:20 utc
Post by luchtzak » 26 Jan 2020, 14:15
jan_olieslagers wrote:
26 Jan 2020, 10:31
Only the forums?
Post by jan_olieslagers » 26 Jan 2020, 14:35
Sorry, I couldn't say; I only tried search.php?search_id=active_topics, the "active topics", my usual point of entry :)
Post by Homo Aeroportus » 26 Jan 2020, 14:36
26 Jan 2020, 14:15
26 Jan 2020, 10:31
Only the forums?
Yesterday and today. Home page usually accessible but hitting "Active Forums" doesn't go through 8 times out of 10.
Post by Homo Aeroportus » 26 Jan 2020, 16:07
Quick Links > Active Topics.
5 other attempts in last 90 minutes, all OK.
Post by luchtzak » 27 Jan 2020, 09:50
Tech support message:
There were a number of suspicious requests from IP range 114.119.128.0/18 (Singapore) so we blocked this IP range at your firewall.
