Aviation24.be - luchtzak
Re: Aviation24.be - luchtzak
After some initial issues I can now log in to the new url with not a single problem, both from home and from (ahem) elsewhere. Some of the issues mentioned could perhaps be addressed by flushing the browser's cache and/or remove all "temporary internet files" - a trademark solution by one (in)famous software vendor to complicate life :mrgreen:
That said: the original name was quite funny, a bit confusing to foreigners, very very Belgian, I liked it a good deal. The change was only to be expected, yet for me there was no need. The world has gone another tiny step towards the grey...
DeltaWiskey
Post by DeltaWiskey »
03 Oct 2017, 19:51
DeltaWiskey wrote:
03 Oct 2017, 19:32
I have the same problem as well, I have to login almost every time I visit the forum. Very bothersome.
Luchtzak.be or aviation24.be ?
Luchtzak.be, because that is the name in your header... Why can't it work for both url's?
DeltaWiskey wrote:
03 Oct 2017, 20:40
03 Oct 2017, 19:51
DeltaWiskey wrote:
03 Oct 2017, 19:32
I changed some settings, please confirm it's working on both url's!
webstermc
Post by webstermc »
I didn't had any problems anymore since this morning :D
Before, I almost needed to login twice. The first one he did not take and the 2nd one I needed to fill in a captcha.
But now it seems to be ok. Fingers crossed!
DeltaWiskey
For me it seems to be solved as well. Thanks.
Konus
Post by Konus »
webstermc wrote:
04 Oct 2017, 12:51
I always have to fill in a captcha. I wonder why it is ?
Konus wrote:
05 Oct 2017, 11:15
webstermc wrote:
04 Oct 2017, 12:51
I will check with phpBB why the system asks.
The login-issue should be solved now. Please confirm!
Konus
Post by Konus »
05 Oct 2017, 22:05
I could login normally. The issue seems to be corrected. Thank you.
05 Oct 2017, 22:05
Same here: solved.
Bottie
Post by Bottie »
03 Oct 2017, 23:34
DeltaWiskey wrote:
03 Oct 2017, 20:40
03 Oct 2017, 19:51
aviation24.be or aviation24.be ?
aviation24.be, because that is the name in your header... Why can't it work for both url's?
You changed? ;) ;)
vader
Post by vader »
Please notice that login to forum using facebook does not work :)
N 10" 'Simon II' + SCT 5", EOS 70D, Intek AR-109, PlanePlotter: mo and vo
My website: http://www.rnavspotting.pl
Forum: https://www.rnavspotters.pl
vader wrote:
14 Oct 2017, 21:52
Thanks for notifying us. We'll work on it. ;)
14 Oct 2017, 23:01
vader wrote:
14 Oct 2017, 21:52
Please test/check!
vader
Post by vader »
15 Oct 2017, 01:10
Please test/check!
Works fine now.
Trip reports are an important item in our forums, we would like to bring those trip reports to the front page. With ratings. A score will then be displayed on the main site, but also on google, check:
https://www.google.be/search?q=site%3Aa ... e&ie=UTF-8
We have added the cookie pop-up again on the main page, required by EU law.
For more information: https://www.aviation24.be/cookies-policy/
vader
Post by vader »
I was setting up google/facebok login on my forum and found, that here there is one place where you cannot connect forum account with facebook account - using old domain luchtzak .be. Go to UCP > Profile > Manage your external account associations
There is 'Link' button to facebook account. In facebook app, you have to add 2 more links which are missing:
Code: Select all
http://www.luchtzak. be/forums/ucp.php?i=ucp_auth_link&mode=auth_link&link=1&oauth_service=facebook
http://luchtzak. be/forums/ucp.php?i=ucp_auth_link&mode=auth_link&link=1&oauth_service=facebook
BTW: Look forward to set up SSL certificate (https://) here. Easy to install it for free.
Thanks Vader, but we prefer everybody uses www.aviation24.be over the old url ;-)
vader
Post by vader »
25 Nov 2017, 14:37
I see :) so add rewrite rule to old address
Code: Select all
