Aviation24.be software update topic
Re: The www.luchtzak.be update and downtime topic
Post by Acid-drop » 24 Jul 2012, 11:15
we are currently redirecting to the new server, this procedure might take up to 48 hours but in general this is not that long.
It all depend the TTL of the dns entry, you may be able to tweak that settings before the migration.
I'm on the new one already, TTL seems to be 4h.
But there is another prob, we are redirected to http://31.193.177.82/~luchtzak/
the cookie for authentication will fail
Post by luchtzak » 24 Jul 2012, 11:28
Thanks for the information, Bottie and myself changed some settings and if all goes well in max 4 hours www.luchtzak.be will be available on the new server ;-)
Post by luchtzak » 24 Jul 2012, 11:55
www.luchtzak.com is already working!
Post by luchtzak » 24 Jul 2012, 14:33
I am now able to browse on the url again: www.luchtzak.be and not the IP adress (from France)
but apparently in Belgium this is still not the case, please be patient ;-)
Charlie Roy
Post by Charlie Roy » 24 Jul 2012, 17:06
Tapatalk works again :-)
Bottie
Post by Bottie » 24 Jul 2012, 17:35
Charlie Roy wrote:Tapatalk works again :-)
Everything should start to work fine again, if not, just mention it here in this topic.
Sam V
Post by Sam V » 24 Jul 2012, 20:35
luchtzak.be does not work (the adress without www.) when it did before
Bottie
Post by Bottie » 24 Jul 2012, 22:28
Sam V wrote:luchtzak.be does not work (the adress without www.) when it did before
Will be taken care off shortly
Post by luchtzak » 26 Jul 2012, 10:52
Tapatalk plugin has been updated, please confirm tapatalk is working fine!
Post by sn26567 » 26 Jul 2012, 11:33
tapatalk works fine!
Post by luchtzak » 27 Aug 2012, 23:37
www.luchtzak.be has been down for the past 15 minutes, the phpBB-forums are now up-to-date version 3.0.11 ==> https://www.phpbb.com/community/viewtop ... &t=2161321
Post by luchtzak » 30 Aug 2012, 17:18
A new version of the tapatalk plugin has been installed, as I don't have a smartphone I need somebody to check if all is working :idea:
Post by sn26567 » 30 Aug 2012, 23:56
luchtzak wrote:A new version of the tapatalk plugin has been installed, as I don't have a smartphone I need somebody to check if all is working :idea:
It works!
Bottie
Post by Bottie » 22 Sep 2012, 17:14
Due to some maintenance and updates (serverhard- and software), there are some downtimes today.
I hope these won't take too long :)
Thanks for understanding.
Bottie
Post by Bottie » 10 Jun 2013, 21:35
A hardware-upgrade will be performed on June 12th, around 6am. If all, and I don't expect any trouble, goes well, there will a downtime of about 5 minutes.
Thanks for understanding :)
Bottie
Post by Bottie » 13 Jun 2013, 13:27
Serverupgrade is finished. After the anounced RAM-upgrade I decided to do last-minute Hard Drive upgrade.
Server is good to go for another few years (I hope)
Post by luchtzak » 13 Jun 2013, 14:02
Bottie wrote:Serverupgrade is finished. After the anounced RAM-upgrade I decided to do last-minute Hard Drive upgrade.
:thumbup:
Bottie
Post by Bottie » 03 Dec 2013, 14:59
As some of you probably have noticed, luchtzak.be was hard to reach the last hours.
Due to a DDOS-attack on the server, I had to shut down some services untill all was over. On some moments, serverload was over 500 where 4.0 is actually 100%.
Let's hope adjustments I've made help and the attacks are over.
B
Treeper
Post by Treeper » 03 Dec 2013, 19:07
any idea who the criminal/s is/are? or where it came from?
Bottie
Post by Bottie » 03 Dec 2013, 19:20
Treeper wrote:any idea who the criminal/s is/are? or where it came from?
IP-ranges from China, Canada, Taiwan and Jemen ... but that means nothing, they can be 'spoofed'
