Favorite Military Aircraft Model Fighter: F14 Tomcat
A place to discuss military aviation: airshows, stunning pictures, weapons, etc...
hytek02
Post by hytek02 » 27 Nov 2018, 01:36
The F-14 Tomcat was made famous by the movie, "Tom Gun." While many people confuse the F-14 the Air force F-15, there are distinct differences that can be easily spotted by a trained eye. First of all, the F-14 is a two seated fighter <a href="http://www.modelworksdirect.com">aircraft model </a>and structurally reinforce to make short hard landings on military Aircraft Carriers.
Provided below is a handmade Aircraft fabricated from Scratch and measuring 36 inches / 91 Centimeters. The model is made of composite materials consisting of wood, resin, metal, plastics and more. The total build time was 3 months at over 400 hours of fabrication time. This model is not built from an y
Specifications
Function Carrier-based multi-role strike fighter
Contractor Grumman Aerospace Corporation
Unit Cost $38 million
Propulsion F-14: two Pratt & Whitney TF-30P-414A
turbofan engines with afterburners;
F-14B and F-14D: two General Electric F-110-GE-400
augmented turbofan engines with afterburners
Thrust F-14A: 20,900 pounds (9,405 kg) static thrust per engine;
F-14B and F-14D: 27,000 pounds (12,150 kg) per engine
Length 61 feet 9 inches (18.6 meters)
Height 16 feet (4.8 meters)
Maximum Takeoff Weight 72,900 pounds (32,805 kg)
Wingspan 64 feet (19 meters) unswept, 38 feet (11.4 meters) swept
Ceiling Above 53,000 feet
Speed Max Mach Number = 1.88
Cruise Mach Number = .72
Carrier Approach Speed = 125 kts
Mission Radius 500 nm Hi-Med-Hi strike profile
380 nm Hi-Lo-Lo-Hi strike profile
Crew Two: pilot and radar intercept officer
Armament Up to 13,000 pounds of
Air-to-Air Missiles (up to)
6 AIM-7 Sparrows
4 AIM-9 Sidewinder
6 AIM-54 Phoenix
air-to-ground ordnance
MK-82 (500 lbs.)
4 MK-83 (1,000 lbs.)
4 MK-84 (2,000 lbs.)
MK-20 cluster bomb
4 GBU-10 LGB
GBU-12 MK-82 LGB
4 GBU-16 MK-83 LGB
4 GBU-24 MK-84 LGB
Re: Favorite Military Aircraft Model Fighter: F14 Tomcat
Post by sn26567 » 27 Nov 2018, 15:05
Welcome to Aviation24.be, hytek02.
