Transatlantic routes
Post by sn26567 » 10 Aug 2018, 17:38
DL43 and SN501, both flying from BRU to JFK today at approximately the same time, have taken quite different routes over the Atlantic, Delta flying much more North than SN.
Can someone explain why? The winds are the same for everybody!
Re: Transatlantic routes
Post by jan_olieslagers » 10 Aug 2018, 18:55
I don't know, perhaps a difference in assigned flight level / altitude?
737MAX
Post by 737MAX » 10 Aug 2018, 19:03
10 Aug 2018, 17:38
It can be due to different ETOPS qualifications.
Or ATC restrictions.
As I see on flightaware, flight time for both flights were approx the same.
Post by Homo Aeroportus » 10 Aug 2018, 19:11
So many flights across the pond for the assigned tracks.
Green lines are the Westbound tracks for 10AUG 1130-1900Z
Blue lines are for 11AUG 0100-0800Z.
Below is a screenshot from FR24 at 1900Z for flights into KJFK, and this is only the late wave and only into KJFK.
Just add the flights to all other NAM destinations ...
Amazing.
Post by DIBO » 10 Aug 2018, 20:46
10 Aug 2018, 17:38
SN got a much better cruising level out of this, FL370 compared to FL340 and mid-atlantic FL320 for DL until it got out of 'Gander Oceanic'. So probably some oceanic track congestion also played a role in the decision making.
AlexC
Post by AlexC » 23 Oct 2018, 09:39
So lets start with the first statement:
DL43 and SN501, both flying from BRU to JFK today at approximately the same time, have taken quite different routes over the Atlantic, Delta flying much more North than SN.....
Sure they will at a slight diferent Latitude. If you take 2 Aircraft departing at paralel runnaways at the same exact speed they could never take the exact same route otherwise they would crash latest by the time they reach the same altitude. This is obviously never happening because, even on a pararel runnaway departure your STARS and SIDS ( Departure routes and approach routes) are diferent.
So with this in mind,you quickly understand that they could never fly exactly the same line otherwise they would eventually crash ( this if they start and fly exactly at the same time).
Second point, the Vertical and Lateral separation on the north atlantic routes ! Most of these routes are predifined and planned. I guess if 2 aircraft fly the same route they would have to keep Vertical and Lateral separation in order to do so and if they fly at the same time, I guess a horizontal/ lateral minima, would be the best option.
I cannot tell you how far that can be, but i am sure their operations team take that in consideration.
The north atlantic Traffic is however ruled and organized so I would not expect 2 aircraft flying exactly the same route with less then a few miles of separation.
Next point:
I would not be very sure of that, and depending on the time of the year they could be flying above, under or in the centre of JET streams. Temperature and wind speed and direction vary massively and are obviously taken in consideration on your flight planning.
hope this helps.
BR
Alex
Aviation Enthusiast
ATPL A
General Aviation Dispatcher / Operations / Ramp Coordination
American Security specialist and Trainer
