Who Am I ?
Re: Who Am I ?
Post by Desert Rat » 22 Feb 2012, 13:32
Not bad...but it's the ignition leads going to one of the igniter plug...the two half shell's are protecting the plug.
They are not replaced very often, because they are "on condition" parts, they are checked every A or 2A checks. By switching the ignition system....without cranking the engine...this test is called the audible check as a mechanic has to listen at the exhaust of the engine to hear the Clac...clac...clac...of the ignition system. ;)
Re: Who Am I ?
Post by Desert Rat » 24 Feb 2012, 04:49
So these fittings are Rosan type fittings...
Re: Who Am I ?
Post by Desert Rat » 28 Feb 2012, 10:15
New one...
appel
Re: Who Am I ?
Post by appel » 28 Feb 2012, 10:46
Part of a nose gear assembly?
andorra-airport
Re: Who Am I ?
Post by andorra-airport » 28 Feb 2012, 11:11
Hydraulic actuator?
regi
Re: Who Am I ?
Post by regi » 28 Feb 2012, 11:38
here we go again.
First what I see is corrosion. My goodness, it looks like a WWI tank just being excavated. Time for some WD40 ! :)
What else? Mainly a hydraulic piston in working condition ( because it is shiny ) attached to something that looks like a torsion bar. And some hydraulic connectors - distribution block in the background.
I can't answer yet, I struggle with the fact that the cylinder is attached at the side and not in the middle of a fork on a bolt. ( makes me think about a side strut attachment :idea: )
Re: Who Am I ?
Post by Desert Rat » 28 Feb 2012, 11:40
It's an hydraulic actuator but not part of the NLG.
Also, what's the part that the rod-end is linked to?
Re: Who Am I ?
Post by Desert Rat » 28 Feb 2012, 11:52
regi wrote:here we go again.
Hmmmm it's not corrosion Khun Regi...
:D
Juulke
Re: Who Am I ?
Post by Juulke » 28 Feb 2012, 16:35
Is this maybe the landinggearactuator?
Re: Who Am I ?
Post by Desert Rat » 28 Feb 2012, 16:49
And we have a winner, although the right terminology is "retraction actuator".
This one is from the CLG of an A340....
But, now...what is called the part where the actuator rod-end is attached?
Juulke
Re: Who Am I ?
Post by Juulke » 28 Feb 2012, 17:50
My guess is the uplock, but I don't think that's right?
andorra-airport
Re: Who Am I ?
Post by andorra-airport » 28 Feb 2012, 18:28
The actuator rod end is attached to the yoke weld assembly?
Re: Who Am I ?
Post by flightlover » 28 Feb 2012, 18:38
May that be the yoke?
Re: Who Am I ?
Post by Desert Rat » 29 Feb 2012, 13:04
andorra-airport wrote:The actuator rod end is attached to the yoke weld assembly?
It's connected to the barrel upper flange...but the way you call it might by use by other A/C manufacturer.
I'll check tomorrow...if i have time... ;)
Re: Who Am I ?
Post by Desert Rat » 29 Feb 2012, 13:06
Easy one...
appel
Re: Who Am I ?
Post by appel » 29 Feb 2012, 16:56
oil quantity indicator
but i dont know for which part
regi
Re: Who Am I ?
Post by regi » 29 Feb 2012, 17:57
:D
the brown spots are hydraulic fluid rests?
The white spots, isn't that corrosion?
WC_EEND
Re: Who Am I ?
Post by WC_EEND » 29 Feb 2012, 18:57
I'd say an engine oil quantity indicator. Don't quote me on that though.
Juulke
Re: Who Am I ?
Post by Juulke » 29 Feb 2012, 19:13
Isn't this the IDG oil quantity indicator?
Re: Who Am I ?
Post by Homo Aeroportus » 29 Feb 2012, 19:23
Juulke wrote:Isn't this the IDG oil quantity indicator?
You are faster !
Think it's an IDG too but I have a doubt about which engine.
PW4000?
Cheers
